Grimmspeed v Crawford AOS - MY11 WRX - Subaru WRX Forum
post #1 of 8 Old 05-11-2012, 04:15 AM Thread Starter
adamreed is an unknown
Hi,
Quick question. I own an MY11 WRX (EJ25 block) with TBE and 17psi ECU tune. I want to install an air/oil separator and wondering which is the best one for the 2.5l blocks that are considered "heavy breathing". Any comments / feedback welcomed.
adamreed is offline
post #2 of 8 Old 05-11-2012, 02:29 PM
thepants1337's Avatar
thepants1337 is an unknown
I have heard a lot of good things about the grimmspeed AOS. Don't own one personally, just seems to have good reviews. Just my 2¢
thepants1337 is offline
post #3 of 8 Old 05-11-2012, 02:37 PM
street only=GS
track+street= crawford.
if you wanna save some money i can sell you a crawford replica i make. its on you though to buy the $20 worth of hose and mount it high enough for the drain back to work. if you cant mount it high enough then just block off the return port and use it as a catch can that will need drained every now and again.
post #4 of 8 Old 05-11-2012, 02:38 PM
Crawford hands down.
I've heard of too many issues with the GS one to bother with it. The crawford design is better anways, it allows a coolant line to run through it to equalize the temp inside the swirl pot to ensure the condensation stays condensation.
I actually have one on my list since going E85 and running 21psi I'm seeing more blow-by than when I was 93 at 18 psi.
post #5 of 8 Old 05-11-2012, 04:52 PM
its BS, the V2 does nothing. radiant heat coming from something that only gets as hot as 180* doesnt get hot enough to cook off the condensation. iwsti has a thread on it, lot of pissed off guys wanting a solution but for me the regular version works fine.
post #6 of 8 Old 05-11-2012, 08:21 PM
What issues would that be? I have one installed on my car and I can't complain about mine at all.
post #7 of 8 Old 05-13-2012, 09:06 PM
I'd like to see the thread syno, to me a difference in temp means a potential for condensed gas to turn back into fluid. If that coolant line keeps the temp in the AOS warmer than one without it I can see that being a benefit.
Kurt, it looks like it's during more aggressive driving, even to the point where they end up blowing oil from the AOS into the intake. I think it's more of an issue that they managed to slosh oil all the way up the filler neck and it got sucked back into the intake.
post #8 of 8 Old 05-13-2012, 09:40 PM
Gotcha, I can see that happening. But, I'm not tracking the car or anything. So, I should be fine.
