Forge BPV Awareness - Subaru WRX Forum
 6Likes
  • 1 Post By arewmors
  • 1 Post By Haw1es
  • 1 Post By the RIOT act
  • 1 Post By pzr2874
  • 1 Post By BLAZE2099
  • 1 Post By NeverSummer
post #1 of 12 Old 12-07-2013, 05:22 AM Thread Starter
Premium Member
arewmors's Avatar
Forge BPV Awareness
So I am not writing this to bash anyone or Forge. I understand that not everything can be perfect when being manufactured, I was one of the unfortunate unlucky ones. I am writing this as an informative thread to other members that may have boost leaks, and/or to inspect the product when you receive it as best you can.
I've had the Forge BPV for a few months now. Occasionally I would hear the screeching sound you get when you pinch the end of the balloon and let the air out. I first had swapped the IC to TB hose out because that had leaked once before. Which it was probably one of the factors because the end of the stock hose had a crimp in it. I replaced that with a silicone hose. Occasionally still hearing the leak. So I took it to my local performance shop who did a boost leak test and immediately found the issue. The leak was coming from the BPV at the base of the cylinder where it connects to the flange. I took the car home pulled it off and put the stock BPV on until I get a new one. I have posted some pictures of the BPV and what I found to be the problem. After I got the BPV off I closely looked at where it was leaking and there is actually a gap where the two parts meet. So it was leaking the entire time, I may not have heard it every time because the gap was big enough where the air could pretty freely flow out. Other times I think the air pinched the o-ring in it to cause the screech because the gap was made smaller. Mind you I have never taken it apart from where it was leaking either and it was leaking from the day I put it on, so it wasn't user error.
Hopefully this helps someone out there. As I stated previously, this wasn't meant to bash anyone or Forge just wanted to create some awareness to others. There are plenty of people that run this product that have no issues.
Nathan21 likes this.
Andy - 12 WRB WRX
Tuned by Innovative Tuning
294 AWHP / 311 TQ
arewmors is offline
post #2 of 12 Old 12-07-2013, 08:01 AM
Haw1es's Avatar
Haw1es is more helpful than not
Geese that's a big hole, seems like a quality control issue on forges end. Any manufacturer can have the occasional failure though. If that's not fixable, I would contact forge to see if they can help you out.
the RIOT act likes this.
Shane
2010 WRX
2014 F150
Haw1es is offline
post #3 of 12 Old 12-07-2013, 09:57 AM Thread Starter
Premium Member
arewmors's Avatar
Yup I already emailed Forge and the place I bought it from. Hopefully I hear back sometime next week. It will be interesting to see what will be done, if anything.
Andy - 12 WRB WRX
294 AWHP / 311 TQ
arewmors is offline
post #4 of 12 Old 12-07-2013, 10:30 AM
Haw1es's Avatar
That's good, from the photos it clearly shows that the o-ring either failed or was installed incorrectly.I hope they help you out!
Shane
2010 WRX
2014 F150
Haw1es is offline
post #5 of 12 Old 12-07-2013, 11:12 AM
Premium Member
the RIOT act's Avatar
Yeah that kinda stuff happens with anything aftermarket occasionally. I'm positive they'll help you out with a replacement. Don't lose faith in Forge though Andy. I've had mine on for a year and a half with no issues of any kind.
Sent from AutoGuide.com App
arewmors likes this.
Brandon - 13' SWP WRX Sedan
the RIOT act is offline
post #6 of 12 Old 12-07-2013, 05:51 PM
That looks like a bad defect.
Forge will take care of you I'm sure.
Good catch though
post #7 of 12 Old 12-08-2013, 10:51 AM
I'll give ya ten bucks for it
Haw1es likes this.
post #8 of 12 Old 12-08-2013, 10:54 AM Thread Starter
Premium Member
arewmors's Avatar
Fol. Will see Randy. It depends if they want it back for the warranty.
Andy - 12 WRB WRX
294 AWHP / 311 TQ
arewmors is offline
post #9 of 12 Old 12-08-2013, 12:13 PM
NeverSummer's Avatar
They will prob give you another once you send that one back. Then you can resell the new one
NeverSummer is offline
post #10 of 12 Old 01-05-2014, 04:36 PM
Pakal13 is an unknown
Sorry for the bump, but wondering what the end result was.
I have the same in my '12 WRX for 4 or so months now, no issues at all and very happy with it; just curious if Forge resolved things to your liking or not?
Thanks -
Pakal13 is offline
post #11 of 12 Old 01-05-2014, 06:33 PM Thread Starter
Premium Member
arewmors's Avatar
I contacted forge and they had me contact the company I purchased it from. I contacted the company and they were working with forge for a warranty, and the part to be sent straight back to forge. In the process I had the company send me a grimmspeed electronic boost control solenoid in place of the forge as I wanted one since I was going for a protune since it needs to be tuned for. The solenoid isn't as much as the bpv so I still should be getting some money back. I am currently awaiting information from the company. If I don't hear back soon, I will be contacting them to see the progress of the warranty.
Andy - 12 WRB WRX
294 AWHP / 311 TQ
arewmors is offline
post #12 of 12 Old 01-05-2014, 07:58 PM
Thanks for the quick reply - good luck with, and enjoy the Grimmspeed EBCS and the protune!
Pakal13 is offline
