Exhaust from STI to WRX - Subaru WRX Forum
post #1 of 7 Old 07-03-2010, 04:54 AM Thread Starter
rodrigoferrari's Avatar
rodrigoferrari is an unknown
Send a message via MSN to rodrigoferrari
Hi all.
Is it possible to install the STI MagnaFlow Exhaust system on the regular WRX 2008?
Because the WRX has only one tip exit and the STI has 4 tips.
I just need to change the black plastic air difuser from the bumper for the STI version?
In the WRX chassis there is the same spaces to fit the STI exhaust?
Thank you.
rodrigoferrari is offline
post #2 of 7 Old 07-03-2010, 12:33 PM
06f250sd's Avatar
06f250sd is an unknown
Yes, the STI exhaust will fit the hatch, it uses the existing hangers.
DIY '08+ STi Exhaust Install on '08+ WRX - NASIOC
06f250sd is offline
post #3 of 7 Old 07-03-2010, 06:59 PM
fuapiti's Avatar
It can be done, it also looks like zh!t
fuapiti is offline
post #4 of 7 Old 07-06-2010, 04:22 AM Thread Starter
No, I'll not cut.
If I change the rear bumper for the STI version, will it fit in WRX body?
Below the car, the path to pass the exhaust is the same as the STI?
I want 4 tips on rear.
Does anyone has the part number for the STI 2008 Hatch rear bumper?
Thank you.
Rodrigo.
post #5 of 7 Old 07-06-2010, 10:16 AM
I want to say the bumper will be wider because of the STi fenders, so it won't match up 100%. You'll have to check on that though I'm not 100% sure on that.
post #6 of 7 Old 07-06-2010, 10:56 AM
fuapiti's Avatar
It won't fit. Like ^he said, the fenders of the STi are much wider, the two parts (bumpers) are different.
fuapiti is offline
post #7 of 7 Old 07-06-2010, 11:29 AM
split exhausts like the STi are expensive. There are a lot of advantages to the WRX's exhaust layout.
