Divorce waste-gate vs high flow cat downpipe - Subaru WRX Forum
post #1 of 10 Old 03-20-2011, 04:43 PM Thread Starter
Is a high flow cat downpipe really worth the extra $300 over the divorce waste gate?
Prouse is offline
post #2 of 10 Old 03-21-2011, 09:19 AM
Depends what you are doing with your set-up.
Also depends if you NEED the cat for emissions or not (think you do in Canada)
Get a bellmouth with a HF CAT.
post #3 of 10 Old 03-21-2011, 01:49 PM Thread Starter
I don't need the cat here but will it throw up a check engine light if I have a turbo xs catback and a turbo xs catless dp? I was told it may throw the O2 sensors off.
Prouse is offline
post #4 of 10 Old 03-21-2011, 02:02 PM
It may.... Just get the catted one. Save yourself time and headaches. 3-5HP isn't worth it.... That and the smell.
post #5 of 10 Old 03-21-2011, 02:50 PM Thread Starter
But there is no chance of a catted dp and cbe throwing up a check engine light??
Prouse is offline
post #6 of 10 Old 03-21-2011, 02:53 PM
the CEL is somewhat unrelated to the cat. You're changing the piping, the sensor is likely to be unhappy. That's why every engine management system disables the stupid things. Their purpose is to report emissions related errors to the ECU so that a shop doesn't need to actually test your car, they can simply scan the ECU and say "it passes". Turning off the sensor does not hurt your car.
post #7 of 10 Old 03-22-2011, 09:49 AM Thread Starter
Any idea how one would go about disabling the O2 sensor? My mechanic is curious because he has never heard of disabling them, just bypassing them in which case they eventually come back on. He has never worked on anything but chevy, dodge and ford though.
Prouse is offline
post #8 of 10 Old 03-22-2011, 09:53 AM
you can disable them on our cars by flashing the ECU it's an option to select in the program
post #9 of 10 Old 03-22-2011, 10:00 AM
you can disconnect the sensor and wire in a small resistor, it will act like the sensor is reporting back "OK". This the the manual fix for "disabling" the sensor. Most of us just re-program the ECU to ignore the sensor though, which is relatively simple.
post #10 of 10 Old 03-22-2011, 04:28 PM Thread Starter
Thanks for being so patient and answering all my questions. I get it now
Prouse is offline
