-   -   Compounds (http://www.wrxtuners.com/forums/f121/compounds-38210/)
Subi101 08-23-2013 04:08 PM
Compounds
Has anyone heard of someone doing a compound kit on a STI before. there is a rumor i have heard around the Utah area about someone possibly trying it.
Whats the thoughts on it. would it be worth it to do something like that.
brfatal 08-23-2013 04:43 PM
If you want to completely waste your time and money, sure you can.
boo-key 08-23-2013 05:56 PM
549 Attachment(s)
Compound kit as in turbo and supercharger?
brfatal 08-23-2013 07:14 PM
Compound turbo.
boo-key 08-23-2013 09:13 PM
549 Attachment(s)
Yeah, probably a waste.
BLAZE2099 08-24-2013 04:45 AM
The HP-TQ on these setups is awesome. But be prepared to fork out the money on building your motor to handle it first. 30psi is not anything like 14psi.
And make sure you hire somebody good with pipe and how it flows.
Your gonna need to custom make ups, downs IC piping. Gonna need two waste gate setups everything to feed it. Fuel, custom mapping. Two reliable different sized turbos that work well together... And your head on straight enough to realize, things on your car are now gonna break more often than before.
Oh yea, almost forgot... Upwards of 10k to get ya started;)
.................GL...CHEERS!!!
Haw1es 08-24-2013 09:49 AM
Not to threadjack, but could you get a smoother power delivery and more low end punch with a duel supercharger/turbo setup? I would imagine even with a compound setup you would have some lag?
turmic 08-24-2013 10:47 AM
[quote=Haw1es;345033]Not to threadjack, but could you get a smoother power delivery and more low end punch with a duel supercharger/turbo setup? I would imagine even with a compound setup you would have some lag?[/quote]
You can get better response and low end. But, it's a extreme pain to meddle with and our cars don't have tons of room to shove a supercharger/turbo setup or two different sized turbos under the hood. Sometimes the two turbo system has a lag response between one turbo maxing out and the other one picking up good boost to take over the power delivery. So, expect to pay out the ass experimenting with the setup and things not working or breaking till you get it right.
Haw1es 08-24-2013 11:26 AM
Yea, if money wasn't an issue I would definitely go for it. Mainly to have an engine compartment that looks like this,
[IMG]http://i175.photobucket.com/albums/w160/Bigrigger78/Copyof0005.jpg[/IMG]
turmic 08-24-2013 07:41 PM
[quote=Haw1es;345065]Yea, if money wasn't an issue I would definitely go for it. Mainly to have an engine compartment that looks like this,
[IMG]http://i175.photobucket.com/albums/w160/Bigrigger78/Copyof0005.jpg[/IMG][/quote]
Haha, that's crammed as shit though.
BLAZE2099 08-24-2013 09:28 PM
^ so how long to change those spark plugs you say?
FOL
Subi101 08-29-2013 09:26 PM
[quote=brfatal;344778]If you want to completely waste your time and money, sure you can.[/quote]
why would this waste your time?? ive heard of them doing it on diesel trucks. they say they spool quicker because of the small turbo and then the big turbo takes over. is that not how it works??
n8mcd 08-29-2013 11:16 PM
Never seen a sti... But there are some guys in the Dsm community doing this... Think about it... Small turbo for low end and spool time, big turbo for top end... Sounds pretty legit to me... Sure you can get 700hp with one turbo... But that bitch won't spool until 6k... I think it's a good idea for people who have money, time, and are into actually racing instead of dyno numbers....
LW_Black4 08-30-2013 08:48 AM
1 Attachment(s)
[quote=Subi101;348106]why would this waste your time?? ive heard of them doing it on diesel trucks. they say they spool quicker because of the small turbo and then the big turbo takes over. is that not how it works??[/quote]
This is a sequential turbo setup:
[url=http://en.wikipedia.org/wiki/Twin-turbo]Twin-turbo - Wikipedia, the free encyclopedia[/url]
"Sequential turbocharger systems provide a way to decrease turbo lag without compromising ultimate boost output and engine power. Perhaps the most noteworthy application of this system is the fourth-generation Toyota Supra (1993-1998), which is generally regarded as having the most reliable sequential turbo system yet fitted to a production automobile, with a reported failure rate of less than 1% as of 2011"
However, they are more costly and complex (affecting reliability and demanding more design knowledge) than a single turbo setup, and I see little support for sequential setups in the aftermarket industry.
Designed correctly, I'd expect a sequential turbo setup to address the typical performance tradeoffs of; 1.top-end plateau with a small turbo (e.g. OEM WRX, GTI, etc.) and 2. turbo lag of oversized turbos, tailored for high rpm running (e.g. '76 Porsche turbo).
It just may not be worth your while to engineer it yourself.
brfatal 08-30-2013 09:31 AM
No, both turbos will always be working, one doesn't just take over. You will get slower spool up on either turbo individually than you would if you ran either one by itself since the exhaust is being split between them, which is why many cars that come TT stock are converted to single turbo when upgrading. Nor are the results cost efficient.
