Cobb stage 1 help - Subaru WRX Forum
post #1 of 7 Old 09-19-2009, 02:03 AM Thread Starter
09dub is an unknown
Cobb stage 1 help
Alright here it goes, I am new to subaru's I just bought an 09 WRX Sedan, and COBB AP
I reflashed my factory map with the factory map on the AP, so i could keep it that way till my break in was finished. I live in Northen CA
Once it was done i used the dynometer function to test that power.
it came out prety high
295HP
302TQ
peak boost 15.7
So i used the replay, not reflash function and load the AZ/CA/NV stage 1 map
284HP
292TQ
15.1 boost
Replay function again General Stage 1 map
287HP
295TQ
15.1 PSI again
IDK what the problem is, any suggestions would be great. should i try to reflash to stage 1 instead of replay or will i get the same results? what should stock boost peak at? and what should stage 1 boost peak at?
thanks in advance for the help.
09dub is offline
post #2 of 7 Old 09-21-2009, 06:08 AM
Those #'s are to the crank anyways... look about right (all of them). Here are the notes from COBB :
AZ/CA :
Description: Stage1 91 MTv100 - Intended for an otherwise stock 2009
WRX MT vehicle with a stock or cat-back exhaust, STOCK INTAKE
SYSTEM, and STOCK INTAKE FILTER ONLY. 91 or 92 octane fuel. Boost
Targets: ~15.5psi peak boost pressure tapering down to ~11.5psi by
the 6700 RPM redline, +/- 0.8psi.
93OCT:
Description: Stage1 93 MTv100 - Intended for an otherwise stock 2009
SYSTEM, and STOCK INTAKE FILTER ONLY. 93 or 94 octane fuel. Boost
Targets: ~16.5psi peak boost pressure tapering down to ~12.5psi by
the 6900 RPM redline, +/- 0.8psi.
Get a boost gauge (unless you already have one). You are right about where you should be.
post #3 of 7 Old 09-21-2009, 12:15 PM
Blackmist27 is an unknown
i also have the stage 1 on my car too... 09 wrx sedan. love it... waiting to get some more mileage on it before going to stage 2. any pics of your car?
Blackmist27 is offline
post #4 of 7 Old 09-21-2009, 08:09 PM Thread Starter
09dub is an unknown
the only thing that seemed wierd was that all the readings were the highest with the stock map still read in. i reflashed to stage 1 and boost is up to 16.2 now. thanks for the help! hopefully stage 2 soon.
no pics yet it looks stock still, satin pearl white sedan
09dub is offline
post #5 of 7 Old 09-22-2009, 05:38 AM
Did you "feel" a difference?
Are you guys reading psi from the AP only ?
post #6 of 7 Old 09-22-2009, 01:14 PM
Stage 1 is more of evened out map that fixes some fuel issues and gives a slight bump of power. Not a lot of power to the wheels...more to the crank than anything.
post #7 of 7 Old 09-22-2009, 01:42 PM
You'd be able to feel 15% big dog.....
