Cobb Down Pipe Install - Page 3 - Subaru WRX Forum
 4Likes
post #31 of 36 Old 08-07-2013, 11:22 AM Thread Starter
Premium Member
arewmors's Avatar
Originally Posted by man show View Post
O2 sensors are not terribly difficult to remove. I've removed mine several times now. PB Blaster is definitely helpful. An O2 socket is an excellent investment, although it's probably not a tool you will use too frequently, so you could check with your local auto parts stores and see if they have a program where you can borrow one after giving them a small security deposit which you'll get back after returning the tool in good working order (my local AutoZone does this). You shouldn't need an impact gun, just use elbow grease and a small extension or a light hammer tap or two if you have to. I find that when I come across a stubborn bolt, if I step away for a moment, stare at it, cuss at it, get angry at it and return with a small boost of adrenaline, it usually loosens up. A nice fist pump at the end is icing on the cake
Ah I totally forgot about the rental option !Laugh!! I have Advance Auto and Auto Zone 1 minute apart from each others 3 minutes from my house lol. So if one doesn't have what I need, I go to the other. If they have one I may just buy it though, that way I have it when I need it again, if I do.
Has there been any issue with the studs coming out of the turbo, or is that not really a big deal? I have a little bit of worry that something will be heat fused together and won't go right.
arewmors is offline
post #32 of 36 Old 08-07-2013, 09:59 PM
That's ALWAYS a possibility
Reason why you take the o2's out when hot/warm and the DP out cool
If the studs come out/spin... just wrench em out reverse.
post #33 of 36 Old 08-08-2013, 05:18 AM Thread Starter
Premium Member
arewmors's Avatar
So pretty much just keep going and back the stud out all the way and just put it back in when installing the new dp?
arewmors is offline
post #34 of 36 Old 08-12-2013, 05:25 AM Thread Starter
Premium Member
arewmors's Avatar
Thanks all for you help with this. Installed the dp yesterday! Couldn't be happier with it. Install took longer than expected but I took my time to do it correctly.
BLAZE2099 and the RIOT act like this.
arewmors is offline
post #35 of 36 Old 08-12-2013, 05:36 AM
To take your time, is the right amount of time to do it right young padawan.
post #36 of 36 Old 08-12-2013, 06:01 AM Thread Starter
Premium Member
arewmors's Avatar
So very true! I'm paying for it today though.
Andy - 12 WRB WRX
Tuned by Innovative Tuning
294 AWHP / 311 TQ
arewmors is offline
