Cleaning the engine bay - Subaru WRX Forum
post #1 of 10 Old 06-06-2012, 02:20 PM Thread Starter
Deans_socash's Avatar
Deans_socash is an unknown
Is it safe to take a hose and just hose down the engine and parts to clean it of dirt and sand and bugs?
Deans the name , tits are the game
Deans_socash is offline
post #2 of 10 Old 06-06-2012, 03:09 PM
MOST of the time as long as it's a cold engine.
On the other hand, if you are just running water off the engine with nothing else, it's not going to clean much (without degreaser or the likes).
post #3 of 10 Old 06-06-2012, 04:25 PM
You need three things.
Simple Green
Scrubby Brush
Hose with mister
Mist engine with water, spray everywhere with simple green and let sit for a few minutes. Scrub with scrubby brush and rinse off with a healthy dose of water.
Engine bay goes from this:
To this:
In about five minutes.
post #4 of 10 Old 06-06-2012, 07:43 PM Thread Starter
Nice thanks guys. Btw I see you have an aem intake ? How you like it?
post #5 of 10 Old 06-07-2012, 06:41 AM
That's a Perrin CAI I believe.
post #6 of 10 Old 06-07-2012, 07:36 AM
Yup perrin. I'd probably do KSTech if I could do it over again.
post #7 of 10 Old 06-07-2012, 08:25 AM
If anyone wants a really good product to clean their engine, check out P21S Total Auto Wash. It's pretty awesome stuff. I spray it on a completely dirty engine bay (without hosing off), let it soak, and rinse. It will be about 95% clean. Finish it off, let it dry, and apply protectant where applicable.
As for hosing, be sure to protect sensitive electronics. I like to use aluminum foil to cover things like the alternator. Just whatever you do, don't accidentally short +/- with foil... You'll have more problems than a wet or dirty engine bay then.
post #8 of 10 Old 06-07-2012, 10:09 AM Thread Starter
Yea Lmfao shorting out was the priority of my worries. So aluminum foil to wrap the alternator ? Anything else I should look out for even with the sprays and cleaners you guys are recommending ? How should I clean my radiator of bugs without having to take it out? Just keep spraying with water Or???
post #9 of 10 Old 06-07-2012, 10:35 AM
post #10 of 10 Old 07-31-2012, 11:02 AM
BoostinChick is a helpful contributing member
P21S is amazing stuff! But on the cheaper end, Scrubbing Bubbles works just as well, if not better, and only $2.99!
- Sandra
2007 WRX TR | Stage 2 | PAR Gearset (Built by AndrewTech)
BoostinChick is offline
