CEL nearing redline - Subaru WRX Forum
post #1 of 9 Old 09-18-2010, 02:53 PM Thread Starter
Gateseekersubie is an unknown
CEL nearing redline
I recently had a Perrin Dp and Up installed and i now get a CEL nearing redline in 3rd gear. Never happened before the install. If this has been answered in another location please point that out. I do have plans to either add an AP or possibly a custom tune to the setup. I'm guessing that would solve the problem all together. Just curious on what to do until that time.
Gateseekersubie is offline
post #2 of 9 Old 09-18-2010, 04:17 PM
go to autozone and get the CEL code, but I'm betting it was an overboost code
post #3 of 9 Old 09-18-2010, 05:50 PM
wagonracer's Avatar
You hit the nail on the head. Take it easy on the car, and stay out of the boost until you get the right map loaded, or you will regret it. I will let others elaborate.
wagonracer is offline
post #4 of 9 Old 09-18-2010, 07:21 PM
Hondafan's Avatar
You're very likely to throw a code with a downpipe and no tune. Your car is not designed to have additional boost right now, and that is why it's always recommended that you get engine management at the time you get the downpipe. God luck!
Hondafan is offline
post #5 of 9 Old 09-18-2010, 10:12 PM
Seriously...get a tune and take it easy until you do. The stock map can't keep up with the free flowing exhaust path and you will overboost amongst other things like run too rich/lean (read: not good for the engine).
post #6 of 9 Old 09-18-2010, 10:40 PM
chrischilders22's Avatar
chrischilders22 is an unknown
no clue if it is it but mine did the same thing when my tuner and i was doing a road tune, he said it was hitting the fuel cut
turbo xs DP,turbo xs cai, turbo xs FMIC,3port BCS,walbro255 fp, spt catback, perrin BOV, 300ish whp
chrischilders22 is offline
post #7 of 9 Old 09-19-2010, 10:42 AM Thread Starter
Thanks for the info guys. Ill try to make an appt. for a tune this weekend. I live about 3 hours from the nearest shop, but ill be headed there anyways.
post #8 of 9 Old 09-19-2010, 10:54 AM
The tune will make the most of modified exhaust pipes and best of all. Eliminate the CEL and you will be able to enjoy redline pulls. You'll love it
post #9 of 9 Old 09-20-2010, 01:41 PM
anxiouz's Avatar
anxiouz is an unknown
If you can't get out to a tuner at the very least get an AP...um, ASAP.
anxiouz is offline
