Boost gauge question... - Subaru WRX Forum
post #1 of 9 Old 02-04-2012, 10:14 PM Thread Starter
ranchrex86's Avatar
ranchrex86 is an unknown
Hey guys so as most of you know I have a 2011 wrx and I just installed a carbon autometer mechanical boost gauge. My problem is I am only reading 8 to 10 psi when I get into it and i was wondering If I had something hooked up wrong. I have the gauge hooked up to the recirculating valve vaccum line with a t fitting. The car also pulls fine and feels normal. Let me know what you think.
ranchrex86 is offline
post #2 of 9 Old 02-05-2012, 02:42 PM Thread Starter
ranchrex86's Avatar
No ideas?
post #3 of 9 Old 02-05-2012, 05:44 PM
Hmmmm that's where I have mine hooked up at. Do you have a way to run a log to see what kind of boost your actually making according to the ECU?
post #4 of 9 Old 02-05-2012, 06:18 PM Thread Starter
ranchrex86's Avatar
No don't have a access port yet, would like to get one soon none the less I think the way it is hooked up now is wrong.
post #5 of 9 Old 02-06-2012, 12:47 AM
so its the line right off the BPV right? thats the correct spot. autometer isnt really that great. i had same one you had and it would bounce 5-7psi. i used a pill from the OEM EBCS and it dropped it to 2-4psi but still hard to read. id get rid of it and get the electrical Prosport that has a white needle and red background so it looks the same as your OEM gauges. electrical is the way to go. at only $70 its only $20 more than yours.
till you get that or some kind of EM no one will really know if its right.
get the tactrix 2.0 cable for $180, download free rom raider and boom you can start logging and reading you ECU.
post #6 of 9 Old 02-06-2012, 08:10 AM
Chris-pee's Avatar
Chris-pee is an unknown
Could be wrong but you wont see full boost on a stock car until at least third gear right? If he is looking at it through first and second that could be the issue.
Chris-pee is offline
post #7 of 9 Old 02-06-2012, 08:53 AM
^Correct
post #8 of 9 Old 02-06-2012, 12:44 PM Thread Starter
ranchrex86's Avatar
Yup that is pretty much when I am looking at it. I might return it and get an electric gauge. Also got into it last night in first gear and hit 11psi, so i will probably just not worry about it.
post #9 of 9 Old 02-06-2012, 04:50 PM
To high of rpm too will not show full boost.
