-   -   Boost gauge question... (http://www.wrxtuners.com/forums/f121/boost-gauge-question-32006/)
ranchrex86 02-04-2012 09:14 PM
Hey guys so as most of you know I have a 2011 wrx and I just installed a carbon autometer mechanical boost gauge. My problem is I am only reading 8 to 10 psi when I get into it and i was wondering If I had something hooked up wrong. I have the gauge hooked up to the recirculating valve vaccum line with a t fitting. The car also pulls fine and feels normal. Let me know what you think.
ranchrex86 02-05-2012 01:42 PM
No ideas?
psinuse 02-05-2012 04:44 PM
Hmmmm that's where I have mine hooked up at. Do you have a way to run a log to see what kind of boost your actually making according to the ECU?
ranchrex86 02-05-2012 05:18 PM
No don't have a access port yet, would like to get one soon none the less I think the way it is hooked up now is wrong.
synolimit 02-05-2012 11:47 PM
so its the line right off the BPV right? thats the correct spot. autometer isnt really that great. i had same one you had and it would bounce 5-7psi. i used a pill from the OEM EBCS and it dropped it to 2-4psi but still hard to read. id get rid of it and get the electrical Prosport that has a white needle and red background so it looks the same as your OEM gauges. electrical is the way to go. at only $70 its only $20 more than yours.
till you get that or some kind of EM no one will really know if its right.
get the tactrix 2.0 cable for $180, download free rom raider and boom you can start logging and reading you ECU.
Chris-pee 02-06-2012 07:10 AM
Could be wrong but you wont see full boost on a stock car until at least third gear right? If he is looking at it through first and second that could be the issue.
pzr2874 02-06-2012 07:53 AM
^Correct
ranchrex86 02-06-2012 11:44 AM
Yup that is pretty much when I am looking at it. I might return it and get an electric gauge. Also got into it last night in first gear and hit 11psi, so i will probably just not worry about it.
synolimit 02-06-2012 03:50 PM
To high of rpm too will not show full boost.
