Boost Gauge Install - Subaru WRX Forum
post #1 of 20 Old 02-02-2012, 02:49 PM Thread Starter
thepants1337's Avatar
thepants1337 is an unknown
Boost Gauge Install
Hey everyone, Cobb just released their stage 1/2 maps for the 2012 WRX + AEM CAI. I just ordered a SMY Clustermaker and AEM Boost Gauge to monitor the boost and make sure I'm using the right wastegate cycle map. I haven't installed the gauge yet since I'm waiting on the clustermaker to show up but I wanted to ask,
does anyone have a good link for a write up or video on how to route/wire the boost gauge in the newer WRX's?
Thus far I found a few how to's but they weren't for my particular gauge or on a 2012.
Thanks for any/all help,
Thepants
thepants1337 is offline
post #2 of 20 Old 02-03-2012, 07:05 AM
Mechanical or Electrical? Link ?
There should still be the grommet in the firewall like on the old ones. The only thing that MIGHT have changed is the tap for the power source.
post #3 of 20 Old 02-03-2012, 09:09 AM Thread Starter
post #4 of 20 Old 02-03-2012, 09:47 AM
You get the harness with it ?
Nice gauge BTW
post #5 of 20 Old 02-03-2012, 10:02 AM Thread Starter
I got the SMY Clustermaker to mount it in. Here's the link:
SMY ClusterMaker Dual Gauge Pod 52mm Subaru WRX / STI 2008-2012 / Forester XT 2009-2012 at RallySportDirect.com
Thanks, I think it's pretty nice but I'm also a noob so it's good to hear I'm not the only one.
post #6 of 20 Old 02-03-2012, 10:11 AM
No, did it come with the harness for plug-n-play ? If it did, the instructions are straight forward. Only thing to look for is the rubber grommet on the firewall.
post #7 of 20 Old 02-03-2012, 10:43 AM Thread Starter
To be honest I'm not sure. I think I have to use electric tape and setup the wires correctly, because I don't see a harness. How would I check?
post #8 of 20 Old 02-03-2012, 12:02 PM
Some have options to buy a harness which makes it an easy plug-n-play install. This one doesn't have an option after looking into it a little more. I haven't played with one of the newer gens so I wouldn't know where to tap the power (I am assuming you can use anything that has accesory power) like the clock or the cigarette lighter. I did the one in my Fozzy and it was a nightmare compared to my last WRX's.
Someone else may chime in. Ask Synolimit or RcrsWetDream as they have later models.
Good luck
post #9 of 20 Old 02-03-2012, 12:08 PM Thread Starter
^Bump^ for synolimit or RcrsWetDream . lol:-D
post #10 of 20 Old 02-03-2012, 02:56 PM
do this...all 08+ are the same.
your directions should tell you what wire is power, ground, ACC, and maybe illumination if your gauge changes color for day and night. this link will tell you want fuse is what. and you dont have to just do those 3 loctaions as many are constant powers, ACC, etc.
Wiring for Prosport Premium Boost Gauge
post #11 of 20 Old 02-07-2012, 11:56 PM
djc1827 is an unknown
!Laugh!how bout an accessport
11.82 at 116mph
stock turbo 2011 wrx
337whp 411tq
djc1827 is offline
post #12 of 20 Old 02-08-2012, 02:25 PM Thread Starter
Already have one <3 and it's pretty awesome. lol
post #13 of 20 Old 03-13-2013, 06:03 PM
RexLove320 is an unknown
Send a message via AIM to RexLove320
bringing post back from the dead....
SO, i did this same exact wiring as described on in this picture(from wrxforums) and used the dude's method to tap the fuses.
1 problem. It won't shut off when i turn the car off!! I'm pretty sure its +12v constant fuse that the red goes into but i can't seem to figure out how to turn that ########## off!
I don't want it to kill my battery....anyone run into the same problem? !Cry!
RexLove320 is offline
post #14 of 20 Old 03-14-2013, 06:54 PM
If its not going off your on a fuse that's constant. You just need to find a ACC fuse. Use a light bulb tester with the car off and see which fuse has no power when off. Click the key on and watch the tester light up, there's your fuse.
This, or you must have wires mixed up.
post #15 of 20 Old 03-14-2013, 10:43 PM
ah! ok, yea i just read the supplied instructions...it says ACC power...this dude's write up says it has to be constant...cool man, thanks for the tip! ill check it out tomorrow
