Boost control solenoids..yah or nah? - Subaru WRX Forum
post #1 of 3 Old 06-01-2012, 07:43 PM Thread Starter
Heard a bit bout boost control solenoids...alot of guys running grimmspeeds. Im a little new to these...sounds like u can adjust ## boost? Is there more to them then i am seeing. I am seeing guys w TBE, a protune and CAI and a Boost control solenoid in a '11 wrx pushin 300 hp??? They worth the dollar spent or not?
thesaltyguy is offline
post #2 of 3 Old 06-01-2012, 08:19 PM
bad grocerygetter's Avatar
Yes they are good to go with, no they aren't an adjustable device. And when you install one it must be tuned for immediately. With that list of mods, I dunno if those numbers are right, maybe close, I'm sure someone will chime in to verify that. Mine is older and has the 2.0 with a base of 227 HP(at the crank, brand new) the 2.5s has 260ish I believe so they may get close with that list of stuff.
Kevin.
bad grocerygetter is offline
post #3 of 3 Old 06-01-2012, 08:58 PM
The stock 2 port isn't that bad. You can use yours till like 20psi which you can't get to at stage 2 so save your money. Till you get injectors and an aftermarket intercooler than maybe get one.
