-   -   Boost control solenoids..yah or nah? (http://www.wrxtuners.com/forums/f121/boost-control-solenoids-yah-nah-32571/)
thesaltyguy 06-01-2012 08:43 PM
Heard a bit bout boost control solenoids...alot of guys running grimmspeeds. Im a little new to these...sounds like u can adjust ## boost? Is there more to them then i am seeing. I am seeing guys w TBE, a protune and CAI and a Boost control solenoid in a '11 wrx pushin 300 hp??? They worth the dollar spent or not?
bad grocerygetter 06-01-2012 09:19 PM
Yes they are good to go with, no they aren't an adjustable device. And when you install one it must be tuned for immediately. With that list of mods, I dunno if those numbers are right, maybe close, I'm sure someone will chime in to verify that. Mine is older and has the 2.0 with a base of 227 HP(at the crank, brand new) the 2.5s has 260ish I believe so they may get close with that list of stuff.
synolimit 06-01-2012 09:58 PM
The stock 2 port isn't that bad. You can use yours till like 20psi which you can't get to at stage 2 so save your money. Till you get injectors and an aftermarket intercooler than maybe get one.
