-   -   Aps bov (http://www.wrxtuners.com/forums/f121/aps-bov-33292/)
jmiah007 11-21-2012 07:40 PM
Aps bov
Ok so I've looked around and I cannot seem to find a good solution to this. I just got a 08 WRX. Anyways I got an APS BOV and it turns out it has the more triangular flange off the older WRX's and from some research I've done the 08+ intercooler. I'm looking into having a new flange machined, but I was trying to figure out how difficult it would be if I found a good price on a stock STI TMIC and replaced mine with that. Any help would be appreciated.
psinuse 11-21-2012 08:27 PM
Well what was wrong with the stock BPV?
BLAZE2099 11-21-2012 08:37 PM
It didn't go psssshhhhh! Duh
BLAZE2099 11-22-2012 05:16 PM
You can also buy a new flange on eBay for your noise maker. There like five bucks.
psinuse 11-22-2012 05:19 PM
Now we don't know that he is doing it for the noise...He may actually need one.
jmiah007 12-05-2012 05:12 PM
I'm just getting ahead of the curve as I'm looking at a full turbo back exhaust intake, and vf52, with boost up to about 20+ PSI so this is a good hybrid for all options. Its not a 50/50 but a true hybrid that still recirculates for keeping the turbo spooling while releasing exess with a nice sound.
psinuse 12-05-2012 07:22 PM
Doesn't the 08 come with a vf52 turbo? You really don't need a BOV for what your going to be doing.
jmiah007 12-06-2012 12:34 PM
No the 08's have a different turbo that falls on it's face over 5K, the VF will pull stronger to 6.5K. I know I don't "need" it but I do like sound, without messing with tuning for a full atmospheric BOV.
psinuse 12-06-2012 02:58 PM
Almost every WRX turbo falls on it's face around that rpm. Don't think it was the TDO4 I wanna say it was a vf48 or something. I don't understand the whole "sound" thing. I'm running a stock BPV with a 20g and a build motor, but to each his own I suppose.
WrxCruising 12-06-2012 06:00 PM
I'd rather do whatever is better for the car, rather than what sound you like... just my .2
BLAZE2099 12-06-2012 06:37 PM
Told ya so!
synolimit 12-06-2012 08:58 PM
[quote=psinuse;288410]Almost every WRX turbo falls on it's face around that rpm. Don't think it was the TDO4 I wanna say it was a vf48 or something. I don't understand the whole "sound" thing. I'm running a stock BPV with a 20g and a build motor, but to each his own I suppose.[/quote]
08 wrx tdo4
09+vf52
08+sti vf48 i believe
turmic 12-06-2012 10:31 PM
Scott is right. :p
psinuse 12-07-2012 04:24 PM
[quote=synolimit;288423]08 wrx tdo4
09+vf52
08+sti vf48 i believe[/quote]
Thanks I couldn't remember when they did the switch for the stock WRX turbos.
I would add the with a vf52 turbo you can get some pretty solid numbers out of it...run 11's with the right setup and tune.:beatentod
RcrsWetDream 12-07-2012 08:34 PM
1 Attachment(s)
[quote=jmiah007;287968]Ok so I've looked around and I cannot seem to find a good solution to this. I just got a 08 WRX. Anyways I got an APS BOV and it turns out it has the more triangular flange off the older WRX's and from some research I've done the 08+ intercooler. I'm looking into having a new flange machined, but I was trying to figure out how difficult it would be if I found a good price on a stock STI TMIC and replaced mine with that. Any help would be appreciated.[/quote]
If you want to run an STI tmic, you need the TMIC, STI layout turbo, sti intake manifold, sti throttle body.
All in you're north of $1,000. Get a new valve.
FYI, the bpv on your car now is the exact same one the 09's come with and there are literally thousands of 09+ guys running that boost level on their OEM valves. I ran mine at 21 with no issues.
