The intake was easy to install, comes with all needed part , has the usual turbine noise with the rbv blow off sound that everyone loves . I noticed a small gain in power at the 4-6.5k rpm range.
I dont wanna here anything out of your mouth , I've read a few topic forums, and you dont even tune or work on your own car , I bet you dont even know how to data-log . Why would it run lean or rich ?.....the maf tubing is the same diameter.
WHAT ? I asked a question. Can you not answer it ? I do ALL my own work you 18 yr old punk. Hose diameter is out of the question. Too much air and no EM is what I was referring to. Learn what you are doing THEN talk smack. Until then, continue to run your car into the ground.
BTW... I don't pretend to know how to tune, but if you look at the reason for these forums is knowledge for all.
Again, I don't have an 08 rex, so I don't know much about them. But don't blast anyone, especially when you are incorrect. Makes you look like a douche.
So the car isn't running lean ? Have anything to show ? Are you logging anything ?
car is running a hell of a lot better i think, i dont know wtf u mean when i'm "logging" anything. horsepower?? hmm i dunno i can't tell if i got much but it sure does feel like a more smooth RPM Band.. if that makes ne sense
What I meant on logging is, are you checking the a/f ratios ..... Are you using engine management of some sort ? So it does at least feel better ?
Well its official , and I'm not gonna apoligize , the car is running bad , very lean .....16+ volt range at WOT , I've already taken it off . I have complained to agency-power and they said it was a bolt on , and needed no tuneing , but on there website it says it does. After running the intake for a few days , the car seemed slower and when I went to remove it , the whole maf tube and sheilding was retarded hot !!!!! on top of it being slightly larger than stock...........I'm kina pissed ay myself that I didnt notice the MAF tube size..."POS" .......bolt on my ass! The stock setup gave me back all my lost power.....
And your giving people crap about not knowing how to work on cars?Your a moron,maybe you should start lising up junior.And by the way it's 16:1 AFR,not volts.You people better start thinking before you start shooting your mouths off to guys who are just trying to help you....
Aarg matey!
ECU Pirated by RomRaider
