Advices fo WRX 11 Upgrade - Page 3 - Subaru WRX Forum
post #31 of 43 Old 02-18-2012, 11:37 AM
Yes, light blue/dark blue, long and thin. Side feeds are really fat and short and yellow I believe.
post #32 of 43 Old 02-18-2012, 01:48 PM Thread Starter
Blindzzz is an unknown
Dark blue!
synolimit, no words for your help!
Thanks!
Keep updating!
Blindzzz is offline
post #33 of 43 Old 02-23-2012, 11:40 AM Thread Starter
Hi guys,
back with news...
What you all think about a turbo inlet? I expect take a perrin one.
Give me opinions! Feel free guys
Regards!
Blindzzz is offline
post #34 of 43 Old 02-23-2012, 12:47 PM
That'll work. Are they still silicone?
post #35 of 43 Old 02-23-2012, 12:59 PM Thread Starter
Yes, they are. I read about fails of turbo inlets. Only two brands are advised Samco and Perrin, last one is more easy for I get!
Silicone is now seeing a resurgence as a durable and superior material in performance motorsports. Silicone technology allows us to design a turbo inlet hose that is better in all aspects than the OEM part and increases your engines horsepower and performance.
From Perrin Web Site.
Perrins Tech said that gains will be 10-15hp, I think that it is too much, but if they said...
Blindzzz is offline
post #36 of 43 Old 02-23-2012, 01:24 PM
They also claim gains on their CAI's... So take that with a grain (of something).
post #37 of 43 Old 02-23-2012, 04:46 PM Thread Starter
I must agree with you some parts from Perrin are evil spoken. Mainly headers, Tmics (that doesnt fit) and noisily endlinks!
Btw turbo inlets, shift bushings and crank pulleys are well said.
So let me see if this turbo inlet really gives me 10-15hp... or not
Blindzzz is offline
post #38 of 43 Old 02-23-2012, 06:39 PM
for the headache an inlet is not worth it! they are a PITA to install!! i doubt they add power. your turbo is only 2.4" inlet, almost all CAI are 2.59" at the MAF housing. adding an inlet will increase size i believe to 3". i dont see the point in going 2.59", 3", 2.4". if anything i'd think you'd want the system to act like a compressor, start big and go small. that way as the air gets sucked in it speeds up. i dont know though, thats just my thoughts. id do that (so stay stock) or go the same size all the way to the turbo (like me, from the filter to the turbo is full 3")
guys have run the OEM inlet to 400AWHP without issue if that means anything.
post #39 of 43 Old 02-23-2012, 07:27 PM Thread Starter
Your post is great! I can save money($200) and do things on a simple way, sometimes a cars project falls in other dimension and Im avoiding it.
I will never reach 400whp, so stay with stock inlet!
Im trying get out of common tuning, but its hard, a lot of people dont use TGV delete and Header, so I think that Im 1 step forward.
I thought that you all know what Im passing by, doubts, brands, everything and we always want the best to reach higher power as we can.
So parts are coming and its the end and start to plug everything and drive as happy as I can.
Advices are still welcome
Thanks again folks!
Blindzzz is offline
post #40 of 43 Old 02-23-2012, 08:57 PM
I doubt a 2011 has problems with the inlet. But on the older models it seems the inlet use to break or crack when you did turbo changes. Just a frail design and they'd deteriorate over time. The 3rd gen wrxs have a different turbo layout than the older models and I'm sure the inlets are of a better design. So, no worries.
post #41 of 43 Old 02-23-2012, 09:41 PM
thats what i was thinking, its the older and now more brittle ones because of time, heat, etc that have the issues.
however i will say this...the factory tightens the worm clamp very hard on the inlet to turbo. worm clamps when they are over tightened start to dig and eat into their material. "IF" you ever remove that clamp and take off the inlet, there is a huge chance it will have a leak and will be torn when you go to put it back on.
post #42 of 43 Old 02-24-2012, 05:42 AM
I never had a problem with Perrin's suspension parts (sways, enlinks, mounts,etc...)
@Turmic @synolimit
Good looking out on the inlet, didn't think they were any better/worse than the 02-07's
post #43 of 43 Old 02-24-2012, 06:04 PM
That's probably why they were normally replaced when you did a turbo change then...from what Scott said. Makes sense.
