-   -   2013 WRX stage 1 hitting 21lbs... overboost help :( (http://www.wrxtuners.com/forums/f121/2013-wrx-stage-1-hitting-21lbs-overboost-help-41210/)
teethandnails 11-11-2013 01:07 AM
I just removed all the stage 2 mods from my car... 1100 cc injectors, front mount, downpipe, intake, 3 port, and BPV. I then reflashed the car with a 93 octane COBB ots normal wastegate map. The car started and ran fine after I cleared a MAF code (someone turned the ignition to the on position while the MAF was unplugged). The second time I started it, it took a couple seconds to turn over... I figured it was due to the original injectors being installed.
Anyhow... I drove home and decided to make sure everything was ok and safe at 3/4 and full throttle. The car felt STRONG. I plugged the access port in, made a small 3rd gear pull and it hit 21lbs. I backed off, came to a light and turned the car off (wideband isn't plugged in the stock down pipe, and the AEM failsafe will only read for a brief amount of time before it show you a message "UEGO Offline", restarting the car refreshes it and allows you to read boost for like 10 seconds). I made another pull and the boost gauge matched the AP. I then swapped to a 91 octane map and it did the same damn thing. No CEL.. no fuel cut... NOTHING! I have been searching with no answers... Anyone have any ideas?!?
arewmors 11-11-2013 05:17 AM
Is the stock air filter in the stock intake? Have you tried the low waste gate ots tune? Do you have a boost gauge hooked up?
teethandnails 11-11-2013 07:05 AM
i have a gauge hooked up, but its an AEM failsafe which does AFR and boost. My aftermarket downpipe had a bung and my stock one doesn't. On the failsafe, when you remove the afr sensor the gauge doesn't read boost or AFR... kinda crappy. However, it will read boost for like 5 second before it stops. I did verify the boost gauge read the same boost... 21lbs.
arewmors 11-11-2013 07:23 AM
teethandnails 11-11-2013 08:25 PM
I looked at the 2 port and my buddy had the lines swapped. About to log it and see if swapping them fixed it.
teethandnails 11-11-2013 09:50 PM
Ok... uploaded a 91oct LWG map from Cobb. This map targets 15lbs tapering to 13 lbs. The car is spiking at 18lbs then 16.5lbs then 13.6 at redline. It didn't pull any timing anywhere in the map.. car never went past 16 degrees ign advance. Any ideas? Seems as though the two port isn't functioning correctly even when plumbed correctly.
teethandnails 11-11-2013 09:51 PM
Update:
I set WOT wastegate duty cycle to 0%, loaded the map, and the car is only running 8lbs (spring pressure). So it appears the 2 port either has trash in it, or is just not functioning properly, so I guess I will install the 3 port again tomorrow and retune the WDC tomorrow and see what happens. Hope this thread helps someone else in the future.
turmic 11-11-2013 10:06 PM
0% WGDC would mean your only going to get about 8lbs of boost. Which is what you told it to do. :confused:
thekamikaze kid 11-11-2013 11:10 PM
try doing a datalog and sending it to cobb using there AP. I have a stage one tune from cobb ots map that peaks at ~15 psi i actually get almost 16psi maybe they can help?
Nathan21 11-12-2013 09:02 AM
Same thing with what the kid said, I'm running an OTS stage 1 91anc stock intake and I hit peak at 16.5 and avg. around 15.4
