2011 WRX need some parts knowledge - Subaru WRX Forum
post #1 of 23 Old 10-19-2011, 10:02 AM Thread Starter
Shake and bake is an unknown
Alright so here it go's I'm planning on going stage two and trying to do it for the best bang for the buck.. So I came across a Perrin front down pipe for 200 bucks but haven't gotten it yet..would that work fine to go stage 2 or should I really get the full down pipe.. Intake k&n says the typoon intake makes 17 hp is that bs or should I look into getting a different brand one..and I noticed on some cai they don't go all the way to the throttle body they just cancel out the flex hose peice.. Is that a power loss.. And lastly ap vs Perrin tunning maps..
Thanks
Shake and bake is offline
post #2 of 23 Old 10-19-2011, 11:46 AM
So you already have the AP ?
post #3 of 23 Old 10-19-2011, 12:02 PM Thread Starter
No I don't have it yet..
post #4 of 23 Old 10-19-2011, 12:28 PM
Then it may not be the best bang for your buck.
Get a full downpipe and the intake that your Open Source tuner like/can tune for better.
post #5 of 23 Old 10-19-2011, 12:41 PM
Thanks
The intake only goes up to the turbo inlet hose, basically up to the front of the intake manifold on the passenger side. The turbo inlet hose then connects to the turbo, which then connects to the intercooler, which connects to the throttle body hose, to the throttle body.
The intake is only the first 18" of the intake tract, and does not connect to the throttle body. I've never been into K&N... No experience with them personally, but they always just seem to be the big brand that I tend to avoid. Other, more subaru-oriented brands, for an intake would be KSTech, Perrin, AEM.
post #6 of 23 Old 10-19-2011, 02:39 PM Thread Starter
Does anybody know of a good tuner on the west coast
post #7 of 23 Old 10-19-2011, 02:54 PM Thread Starter
And looking at cobbs dyno sheet stage 2 doesn't really improve very much.now going stage two and getting pro tuned will that make a bigger difference or is it not worth going stage 2..
post #8 of 23 Old 10-19-2011, 05:39 PM
ABQMK2's Avatar
ABQMK2 is an unknown
Im no subaru expert but i went stage 2 including drop in filter, downpipe and pro tune on a dyno jet dyno for $675.
here a link to my thread...maybe this can help you.
2011 WRX, I went stage 2 and protuned for $675 :)..dyno results inside
stage 2 is alot of fun
good luck Mr. Bake.
Cam tuned stage 2 2011 WRX
270HP/340TQ @ 17PSI 91 Octane
Jake
ABQMK2 is offline
post #9 of 23 Old 10-20-2011, 06:08 AM
Stage 2 NON-ots tunes will make a big difference from the OTS tune.
You can call COBB and try to locate a tuner in your area or just wait for someone around here to chime in.
Good luck
post #10 of 23 Old 10-20-2011, 02:11 PM
jimbo058's Avatar
jimbo058 is an unknown
My tuner said intake airflow is not an issue until you go over 450HP+. So, any claim that CAI's add HP is pure BS. CAI's that are installed without tuning for them will lead to lean burning conditions, which will be baaad for engine longevity !!! Most reputable CAI vendors will supply a tune to compensate for the change in airflow ... nuff said as there is an entire thread devoted to this ... bye
jimbo058 is offline
post #11 of 23 Old 10-20-2011, 03:45 PM
STIster is an unknown
Church Automotive in Wilmington. Ask for Shawn.
STIster is offline
post #12 of 23 Old 10-20-2011, 04:16 PM
your tuner needs to start tuning newer cars then cause he's feeding you BS.
Yes the stock intake will limit power at some point but you can't say a bigger, smoother, better filter can't and won't add power, it's physically impossible. Tune anything and power increase can be seen.
post #13 of 23 Old 10-20-2011, 04:35 PM
blk05WRX's Avatar
Personally I think just flashing the Stage 1 from Cobb on your car will give you at least 6 months worth of fun. During that six months, save up for a full length down pipe and intake.
Yes, custom tunes can make more horsepower than Cobb's maps, but not all tuner's are created equal. I'm only 15 minutes from one of the top tuners in the country but I've been very happy with the Cobb stage 2 map for over two years now.
2005 WRX Cobb Stage 2
2009 Outback
blk05WRX is offline
post #14 of 23 Old 10-21-2011, 12:16 AM Thread Starter
Thanks every body for the time you took to write all these good things..I'm just Gunna do the Cobb stage one then save up for a dp,cai and grimmspeed 3 port..then go stage two and pro tuned..
post #15 of 23 Old 10-21-2011, 12:20 AM Thread Starter
Now I got the knowledge from reading other people thread about how u should get the grimmspeed 3 port..should I get that while I'm On stage one or not really needed..
