2011 wrx build :) - Page 2 - Subaru WRX Forum
 1Likes
Closed Thread
post #16 of 315 Old 08-31-2011, 06:00 AM
I thought the rev'd manifold helped with preventing bends in the FMIC pipes and quicker air charge ?
Correct me if i'm off my rocker
post #17 of 315 Old 08-31-2011, 08:14 AM
It's a tiny bit shorter with a stock location turbo.
The only problem with stock on 08+ is you can't use a stock location turbo and go reversed manifold; you need to do what syno did or just buy a pre 08 WRX/STI manifold.
post #18 of 315 Old 08-31-2011, 09:03 AM
Thats a ton of modification thats needed. ^^Thanks
I agree the PnPnC does make a difference on the stock location IC with phenolics and TGV delete...
post #19 of 315 Old 08-31-2011, 11:02 AM Thread Starter
it helps with all FMIC kits that run clockwise piping. it literally knocks off 2 feet or more. our wrx's that have the plastic mani that has the TB facing the drivers strut tower has FMIC piping that runs counter clockwise so the pipe is very short to beging with. going reversed keeps my bends down and a little bit of lenght because putting the STI mani on will make me use the cold side STI piping.
like chris said reversing the stock 08+ mani would be hard but not impossible. the power steering pump would need removed and would have to go rotated. all you have to do is get at least 8mm phenolic spacers, buy a shorter alternator belt so you can losen the alternator tensioner and push it down all the way and install the new belt, then bolt the mani on back wards. if you have a DBW TB you have to flip it so the motor sits upward so it doesnt hit the AC pump. if you have DBC you need to remove the AC pump i believe. then of course get piping to fit.
post #20 of 315 Old 08-31-2011, 12:28 PM
Look into the KSTech spacers. Depends who does you porting, the KSTech ones match the port well.
IIRC, GS doesn't port match to their own spacers... maybe that was a long time ago.
post #21 of 315 Old 09-01-2011, 10:38 AM Thread Starter
i already bought used 8mm GS for $50 so i saved a little. as you can see there a little larger like the gaskets so maybe before install ill PnP the mani. im sure the kstechs are the same or else if you PnP your mani or TGV's then the spacers would be in the way of flow.
post #22 of 315 Old 09-02-2011, 10:36 PM Thread Starter
[QUOTE=black beast2;266429]Why the new mani, especially for someone like you who cares a lot about weight loss? [QUOTE]
if you cared haha
post #23 of 315 Old 09-02-2011, 10:39 PM
Vs the stock mani + tgv's?
post #24 of 315 Old 09-02-2011, 11:12 PM Thread Starter
ill know when i pull them. you made a good point too, the motors and butterflys and such should add weight to the plastic mani that they might end up being the same in weight. of course real test would be tgv less and then compair.
post #25 of 315 Old 09-03-2011, 09:40 AM Thread Starter
yes i no its horrible, anyone photoshop?
post #26 of 315 Old 09-03-2011, 09:59 AM
wrx1456's Avatar
wrx1456 is more helpful than not
^^ I would go all white. White wheels, white grill, mirrors, etc. But I like solid color cars. Just a personal opinion. As a two tone that looks good. Or do every thing above the bottom of windows black, door post, full wing, trunk, tint windows dark????
06 STI
http://www.armslist.com/?utm_source=c000017&utm_medium=plink&utm_campaign=p017903
wrx1456 is offline
post #27 of 315 Old 09-03-2011, 10:31 AM
wrx1456's Avatar
Feel free to send payment for the graphic design to my paypal account
06 STI
wrx1456 is offline
post #28 of 315 Old 09-03-2011, 08:03 PM
You'd need to submit a un-ms painted STI or other people would have to find their own photo. Because the ms paint job destroyed the features of the car. I have photoshop...but, i'm not the best with it.
post #29 of 315 Old 09-04-2011, 11:08 AM
Post the original pic and I will see what I can do.
Kjott21 is offline
post #30 of 315 Old 09-04-2011, 03:40 PM Thread Starter
lmao!! love it
Closed Thread
