20 psi boost stage 1+ 2011 wrx - Page 2 - Subaru WRX Forum
post #16 of 20 Old 11-23-2011, 10:39 PM
Cobb swears the "revert back to stock" option will put the check sums back to what they were before the AP was changing things. Everytime you flash you change the check sum. But, revert back to stock supposedly goes back to the original check sum.
post #17 of 20 Old 11-24-2011, 05:48 AM
Not sure about the newer models, but the ECU also records the date of the last flash.
post #18 of 20 Old 05-07-2012, 05:15 AM
turbofreak666 is an unknown
Thumbs up
Originally Posted by Shake and bake View Post
Alright guys thanks alot..well sounds like it's surly not worth it..any way to sneak a little more power out of it..
get the biggest intercooler you can get to fit, every 3 degree you drop you gain a horse power. alot safer than to much boost.
turbofreak666 is offline
post #19 of 20 Old 05-15-2012, 05:10 PM
MR_WRX is an unknown
Go on COBB' s forum and they claim it is not detectable if it is uninstalled. Has to do with check sum values.
MR_WRX is offline
post #20 of 20 Old 05-16-2012, 05:52 AM
IIRC, that's only for the '12 models. Did they start it on the '11 models 1st?
