-   -   08 wrx tune/mod (http://www.wrxtuners.com/forums/f121/08-wrx-tune-mod-39354/)
subarupdx 09-21-2013 03:16 AM
08 wrx tune/mod
3 Attachment(s)
I have went with a new Turbo set up and wanted some advice and suggestions on what next to add
08 Wrx 51000 miles
List of Engine Mods :
Invidia Turboback Exhaust
Gt spec uppipe/header combo
Perrin Tmic
Tomica td05 20g Turbo
740cc injectors
DW 65c fuel pump
Grimspeed 3 Port boost control
AEM cold air Intake
(missing tgv deletes, waiting for perrin fmic this spring and will add them then)
Tune was done by Andy at Ftw tuning.
335whp with 345TQ (pump gas) on a conservative tune. Hoping to add the Tgv deletes and change to a front mount here in the next couple of months. thanks for reading!
arewmors 09-21-2013 05:09 AM
Are there any brake upgrades or transmission upgrades in the near future? The wrx transmission can only take so much hp/tq and if your brakes aren't up to par for the power it is capable of then that power doesn't much matter.
Great looking car by the way. Red is quite rare and more rare now that you can't get them in red any more.
subarupdx 09-21-2013 01:46 PM
[quote=arewmors;358946]Are there any brake upgrades or transmission upgrades in the near future? The wrx transmission can only take so much hp/tq and if your brakes aren't up to par for the power it is capable of then that power doesn't much matter.
Great looking car by the way. Red is quite rare and more rare now that you can't get them in red any more.[/quote]
Thanks man, I really wasn't sure about the red when I bought new back in 08 but it's growing on me. I'm looking at getting some used sti brembo breaks, hopefully I deal comes my way. As far as transmission I don't ever get on it in first or abuse the tranny, I've heared the 08 + have a somewhat better quality tranny then the 06 07s. But when it does go boom ill be looking at a 6speed or ppg gears, gotta do some more research to see what my best route will be.
boo-key 09-22-2013 01:11 AM
549 Attachment(s)
Probably wouldnt hurt to upgrade your stock plastic bpv to a more sturdy aftermarket one that can handle more pressure. Might I suggest a forge :sneaky:
subarupdx 09-22-2013 02:27 AM
[quote=boo-key bear;359282]Probably wouldnt hurt to upgrade your stock plastic bpv to a more sturdy aftermarket one that can handle more pressure. Might I suggest a forge :sneaky:[/quote]
I was going to but a lot of my friends with bov have problems. My tuner said hes never seen a problem with the stock one under 400whp, I rememeber him saying our stock ones handle up to 30psi (correct me if I'm wrong)
boo-key 09-22-2013 04:48 AM
549 Attachment(s)
You shouldnt have a problem with a bov unless it is leaking or 100% vent to atmosphere. The following is taken straight from unabombers manifesto bov faq. Have the OEM BPVs changed over the years? Yes. 08+ Subarus have a BPV that is plastic. So if you for some reason you have a plastic BPV, it will not hold as much boost as the old metal ones. The plastic ones will only hold ~17PSI give or take.
subarupdx 09-22-2013 05:51 AM
[quote=boo-key bear;359330]You shouldnt have a problem with a bov unless it is leaking or 100% vent to atmosphere. The following is taken straight from unabombers manifesto bov faq. Have the OEM BPVs changed over the years? Yes. 08+ Subarus have a BPV that is plastic. So if you for some reason you have a plastic BPV, it will not hold as much boost as the old metal ones. The plastic ones will only hold ~17PSI give or take.[/quote]
Good to know, ill look into it. I have a good friend with the same set up as mine on an 07 wrx and he's been running it since early 2009 with the stock bov and no problems. Honestly one of the reasons I went this route is cause of him, he's had no problems what so ever with his car and is reaching 80k miles 330whp, great gas mileage (depending on driving habits), 4 door, AWD, I'm getting off topic here lol but what a great car
boo-key 09-22-2013 06:05 AM
549 Attachment(s)
His has the metal bpv. Yours has the plastic one. They changed in 08.
arewmors 09-22-2013 08:38 AM
I recommend the forge bpv. Great product for a decent price.
BLAZE2099 09-22-2013 11:09 AM
^ no , Cobb XLE!!!!!!
Yes BOV's do cause your friends problem because they are atmospheric. You want a good BPV.
Forge and Cobb are both great products.
Stay away from turboXS and HKS for this product. These companies other parts are great. Although they should stop making BOVs immediately!
Good luck OP;)
Lightning red and yellows FTW!!!!!!
pzr2874 09-22-2013 01:26 PM
I prefer Forge over COBB for one reason only... price
$150 vs $300
Does the same damn thing.
subarupdx 09-22-2013 01:53 PM
Ill have one ordered next week, thanks for all the help and advice!
BLAZE2099 09-22-2013 02:08 PM
True Paul. I'm just one of those whores who doesnt like too big of a mix of brands under my hood.
pzr2874 09-22-2013 05:01 PM
Wish that were the case on my Speed.... COBB only makes so much stuff...
BLAZE2099 09-22-2013 06:39 PM
I'll probably keep the entire build on mine to about six brands between HP and suspension
Which is still too many for my taste
