08 WRX low rpm stutter - Subaru WRX Forum
post #1 of 11 Old 01-13-2011, 04:21 PM Thread Starter
rwatkinsii's Avatar
rwatkinsii is an unknown
Last week i bought a 08 wrx with 28k
Currently i installed
spt catback
cobb tuner
k&n
Turboxs Hybrid 50/50 bov
The issue i have is around 2500 rpm the engine seems to sputter not like its gonna stall just like dead on power then all kinda power as rpm go up to 2700-3k. It dont matter what map i use stock or stage 1 93 oct or any between. Is this the turbo spooling? It was like this before the BOV so i know thats not the issue.
Thanks for your help and sorry if this is covered elsewhere i searched around but not sure what to call this.
rwatkinsii is offline
post #2 of 11 Old 01-14-2011, 05:55 AM
If you read the COBB notes on "stage1" you will see that the tune is not designed for anything but the modifications that are on the notes :
Hardware Requirements: Otherwise stock vehicle with a STOCK INTAKE SYSTEM ONLY. The addition of any other hardware may make the vehicle perform poorly.
Fuel Requirement: 93 or 94 octane. If detonation is present, you
should use octane booster or switch to a calibration developed for a lesser quality fuel <-- not sure if this pertains to you as I don't know what fuel you run up there.
Go get your firmware updates as well.
The only thing that is with what you have is the catback. Go get a protune or take the BOV and intake off... You are in fact running lean
post #3 of 11 Old 01-14-2011, 09:57 AM
A pro-tune will fix your issue. If you use off-the-shelf, generic maps, you must stick to the specified map notes. Any major deviation from them will cause problems like the one you're experiencing.
post #4 of 11 Old 02-15-2011, 11:58 PM
sicc_soul's Avatar
sicc_soul is an unknown
my money says the k&n is the issue (cobb not setup for it) I was running a perrin intake without a pro tune and had the exact issue
sicc_soul is offline
post #5 of 11 Old 03-07-2011, 08:45 PM Thread Starter
rwatkinsii's Avatar
Ok i figured out the problem. I was using the 93 octane map and apperently the gas station was not pumping 94 like it said. I put a bottle of octane boost just to try and it no longer has the sutter.
post #6 of 11 Old 03-08-2011, 01:22 PM
You mean 93 octane....because no one pumps 94.
post #7 of 11 Old 03-08-2011, 01:43 PM
Actually, 94 octane is available in some places Kirt. Although, I haven't seen it in quite some time. Did they stop selling it alltogether?
post #8 of 11 Old 03-08-2011, 02:27 PM
I've never seen it in my voyages in PA.
post #9 of 11 Old 03-09-2011, 05:33 AM
Sunoco USED to sell it IIRC.
We gets nice Petrol down south
post #10 of 11 Old 03-09-2011, 12:45 PM
Sunoco used to sell purple gas in east york at one point too....But, I won't spend the money on race gas. That gas station that use to sell that got closed down too. So, who knows.
post #11 of 11 Old 03-09-2011, 11:30 PM Thread Starter
rwatkinsii's Avatar
Yes I did mean 93. I also did an experiment to test this and put 89 in and the problem returned. Used a quarter tank and put octane boost in and issue was gone. I have lowered the map to the 91 octane one to see if the gas effects it anymore.
