08 WRX 300-350 whp Turbo choices - Page 2 - Subaru WRX Forum
post #16 of 30 Old 08-11-2011, 12:20 PM Thread Starter
Wrxsubie2008 is more helpful than not
Thanks pzr i mean auto-x is a possibility in the future idk if i wanna go as big as a 20g even if i dont auto-x it i was thinking 18g maybe i am not sure.
What do you all think about the
Tomioka-TD05-18G-Turbo
Import Image Racing: Tomioka TD05-18G Turbo for 08+ WRX/05-09 Legacy GT
OR
FP 68HTA (This one has an option for porting)
http://store.forcedperformance.net/m...Code=WRX-Turbo
or
should I just go with a blouch BB turbo
Wrxsubie2008 is offline
post #17 of 30 Old 08-12-2011, 05:59 AM
The HTA is a decent turbo, from what I've seen.
Look into the EVO3 16G
post #18 of 30 Old 08-12-2011, 11:26 PM Thread Starter
Thanks everyone the members here are alot more helpful than nasioc.
post #19 of 30 Old 08-22-2011, 05:57 PM
Who is your tuner? Blouch Turbos are built in Lebanon, PA btw. A 1.5XTR or 2.5XTR are good options. But, you will have to run a FMIC with those turbos.
post #20 of 30 Old 08-22-2011, 07:16 PM
I just found out that Blouch use to build the turbos for Deadbolt...
I'd call Blouch and talk to Mike to see what turbo best fits your needs...Then again I'm running a rebuild Ebay 20g without issues....meh.
post #21 of 30 Old 10-16-2011, 09:37 PM
mitchkeller87's Avatar
mitchkeller87 is an unknown
Here is my list of mods on my 08 wrx and the numbers I put down: megan racing dp, SRS cat back exhaust, 850cc deatschwerks injectors, 255 walbro fuel pump, megan racing lowering spring, td06 20g turbo, turbo xs front mount, turbo xs BOV, AEM cold air intake, FMS up pipe, 357whp, 322wtq on 16lbs boost 91 octane. I am going to do forged pistons and rods, do an external wastegate, 1000cc injectors and run e85 and got for 450-500 awhp. Good luck with your build
mitchkeller87 is offline
post #22 of 30 Old 10-16-2011, 10:13 PM
I don't see you getting 450-500 whp out of a 20G...even on E.
post #23 of 30 Old 10-16-2011, 10:26 PM
I would guess a dyno that gets you almost 360whp at 16psi on 91 octane you can get 450whp no problem
A real 450whp is a different story.
post #24 of 30 Old 10-16-2011, 10:38 PM
tommelleo22's Avatar
tommelleo22 is an unknown
has anyone heard of clutch slippage at around 300wtq on the newer rexes? been hearing a few cases lately ? might want to + the clutch to while you're at it if that's the case
tommelleo22 is offline
post #25 of 30 Old 10-17-2011, 12:25 AM
That's one REALLY SUPER high reading dyno if you hit 357 whp on 91 on 16 lbs.
I wouldn't go throwing those numbers around. You'll start sounding like Synolimit.
Even on a dyno reading that high you won't hit those numbers on E85.
post #26 of 30 Old 10-17-2011, 08:17 AM
Holding fine at 360 wtq.... Stock power for about a year... 300+wtq for almost two years now, same clutch.
I'd say 99% of the guys that needed a new clutch since the 08's came out can't drive worth a damn.
post #27 of 30 Old 10-17-2011, 08:28 AM
ABQMK2's Avatar
ABQMK2 is an unknown
holding 340 TQ here and seems fine..its only been a month since ive reached that TQ #..i often wonder about the clutch though since my peak TQ comes in low.
Cam tuned stage 2 2011 WRX
270HP/340TQ @ 17PSI 91 Octane
Jake
ABQMK2 is offline
post #28 of 30 Old 10-17-2011, 09:19 AM
^Cam should be able to tell you what the "holdback" was/is.
post #29 of 30 Old 10-17-2011, 02:39 PM
*scratches head* Ummmm okay.
post #30 of 30 Old 10-17-2011, 03:17 PM
Its a very high reading dyno and I still doubt its ability to hit 450whp on E85.
