Go Back   WRX Forums > WRX Tech Forums > Bolt-on Tech (2008+ WRX)
Old 07-22-2008, 02:30 PM   #1 (permalink)
Reputation: Cobraonchrom is an unknown
08 Pnp
I am about to go stage two but I am planning ahead cause I know that won't last long, Hi my names Josh and I'm and addict. Haha. I have done a little research on the subject of PNP various parts and I think it's how I want to go for now, But I want opinions and thoughts. First I will list my upgrades. Some are for future use that I may get right now, cause most likely in a year or two I will swap the turbo.
1. PNP/Coat Stock Headers/Up pipe
2. PNP/Coat Stock Turbo
3. AVO TMIC
4. AVO BPV (is this needed or stock ok?)
5. Injectors/Pump
6. Protune
Please comment for me I am just looking to be able to hold my own and have a fairly quick car without too much money right now. Will the injectors and fuel pump be a good addition to the pnp stocker or is it totally uneccesary? I may get them just becuase later if I upgrade the turbo I will already have them on. All and Any criticism is welcome. I am still learning about turbos but I know I'm learning a lot on here. Thanks in advance!
Old 07-23-2008, 09:21 PM   #2 (permalink)
Nothing at all?
By the way, what do you think about this:
AVOturboworld International
Old 07-24-2008, 03:31 AM   #3 (permalink)
Looks fine but the stock BPV is totally fine for even 20PSI. Leave it alone would be my advise.
Engineers can't spell, sorry!
Old 07-24-2008, 07:41 AM   #4 (permalink)
What's your opinion on the solid boost actuator? Would it be a good investment?
Old 07-24-2008, 08:21 AM   #5 (permalink)
Longshot's Avatar
Car: 05 WRX
Not necessary, I wouldn't waste money on it. Get a 3 port bcs after you go stage 2 instead, for much cheaper. Other mods look good, but stay with the stock BPV like mosc said.
DTRacing Tuned
Old 07-24-2008, 11:13 AM   #6 (permalink)
Yea I was wondering if a 3 Port would be a good idea after stage 2. I was looking at the perrin 3 port EBCS Perrin EBCS Electronic Boost Control Solenoid, JSC Speed
I have noticed that I may have a problem with my restrictor pill when I go stage two, Which will be soon. Will the 3port resolve the need to drill the pills? I have read a few posts about this and I don't think I found anything concrete. Sometimes I look at this thing so long I forget what I see! haha
Old 07-24-2008, 11:17 AM   #7 (permalink)
Longshot's Avatar
Car: 05 WRX
That's the one I have, it DOES require tuning (wastegate duty cycle gets lowered 20-25%).
With the 3 port setup you won't have a pill anymore. It eliminates the need for the pill to help hold boost.
DTRacing Tuned
Old 07-24-2008, 11:47 AM   #8 (permalink)
OOOOOOO I gotcha. Now I feel stupid. I did know it required tuning though.
Old 07-24-2008, 08:56 PM   #9 (permalink)
I use a 3-port GM boost solenoid cost me $50 RETAIL. You don't need a fancy EMBC for the job. Yes, they need to be accounted for in your tune.
Old 07-28-2008, 11:45 AM   #10 (permalink)
I definately going to upgrade the solenoid but I was just wondering... Would a EWG remove the need for a new EBCS? I am considering purchasing a GrimmSpeed EWG Up pipe kit. Would it be safe to run the EWG without any other mods (besides a tune)? The only reason I am considering this is because I have heard of good gains with larger turbos which I plan to swap to a deadbolt 18g/20g next year.
Old 07-28-2008, 01:21 PM   #11 (permalink)
Longshot's Avatar
Car: 05 WRX
You can run an EWG on the TD04, a few members on here have it and like it...BUT you should wait til you're stage 2. I couldn't do it just because I'd get sick of the sound of the dump tube. An EWG with a 8cm 20G is a badass combo, but start saving for gears. An EWG has nothing to do with the bcs, therefore you still need to use one. You'll still want to use a 3port bcs when you go bigger turbo so you may as well get the one now.
DTRacing Tuned
Old 07-28-2008, 02:32 PM   #12 (permalink)
there's no reason you can't route your wastegate exhaust path back into your main exhaust after the turbo. You could even keep a Catalytic converter. Just saying.
Old 07-28-2008, 02:50 PM   #13 (permalink)
Yea I'm definately going stage 2 before anything. My DP should be here today. So when I get some time I'm gonna install that and reflash. Then I'm goin with grimmspeed PnP/coated headers w/ hiflow crosspipe and upipe and tgv delete and a 3-port with a protune of course. Then I'm going to start the turbo support mods. What tranny mods are in order if I go w/ 20g? gears/clutch?
Old 07-29-2008, 02:21 AM   #14 (permalink)
Usually a stronger set of gears. The stock on the 02-07 or short and narrow. PPGs are much thicker and wider, which makes them much stronger. I dont know what the 08 gears look like.
Old 07-29-2008, 11:31 AM   #15 (permalink)
Yea I am looking to get a set of straight cut ppg's since I live not too far away from andrewtech. Should I have to worry about any internals at that power level?
