-   -   08+ plastic bpv real world boost pressure limits (http://www.wrxtuners.com/forums/f121/08-plastic-bpv-real-world-boost-pressure-limits-32145/)
Ericinhoodriver 03-06-2012 01:27 AM
What users out there are using their stock plastic bpv in. 08+ wrx and what kind of stage 2 pressures are you running without issues on the bpv? I am not talking about what kind of pressure you heard/read might work or fail, rather what are you tuned to and hitting without plastic bpv issues?
Thanks,
Eric
thepants1337 03-06-2012 09:08 AM
Bump^ I would also like to know this.
thepants1337 03-06-2012 10:42 AM
For info purposes. ---------I am running a 12 WRX at around 17-18 psi with no issues.
Ericinhoodriver 03-06-2012 10:40 PM
That's good information. Thanks! Any others?
synolimit 03-06-2012 10:59 PM
never took mine pasted 18psi. google and you'll find fails.
aponte9511 05-20-2012 07:02 AM
i hit 19.2 a couple of times on the stage 2 + aem and have no issues i know its high for the plastic endtank tmic and plastic bpv to handle so im probable gonna run the lwg map
thesaltyguy 06-01-2012 07:19 PM
Im a little over 19 on mine too. Also stage two and my tuner says im at the limits...much more and ill start blowing stuff...hence im in the market for a bigger TMIC
synolimit 06-01-2012 09:06 PM
The bpv isn't about breaking at high boost like the tmic, its about leaking from opening prematurely. You won't know it and can't do anything about it. Physically though what's going on is the Ecu is trying to target say 19 psi. With the leaking boost the turbo will have to push more boost to reach its target. So the Ecu and boost gauge will see 19psi but your turbo will be pushing 22-23-24psi. A log will be able to tell because flowing that hot of air can cause knock and WGDC will be outta wack. Either way it's a bad thing and stressing the turbo out.
