Scooby Nooby, ECU error codes HELP!!! - Subaru WRX Forum
post #1 of 2 Old 02-09-2012, 03:24 PM Thread Starter
outlaw-ridez is an unknown
Hi, my WRX is playing up, running rough, not starting when cold, fans coming on when cold, and reving itself irratically. I had read that you could connect the black connectors together under the dash and the Check Engine Light would flash in long and short pauses and you could accertain what the fault was. The problem I had was I couldn't tell what the codes were or if it was repeating the codes or if there were lots of them???? HELP!
So I filmed it and here is said film --> http://youtu.be/qE5Jhn23swE
Can anyone work out the codes? or has anyone had this before?
Many thanks for the time you spend looking at this thread.
Outlaw-Ridez
Ps its a JDM 1994 WRX Wagon.
outlaw-ridez is offline
post #2 of 2 Old 02-09-2012, 06:49 PM
AllExtinct's Avatar
Check Engine Light Illuminates
This won't be caused by the upgrade but is a handy check if you have a sensor failure. Follow the procedure detailed below:
Turn ignition OFF.
Connect black connectors under steering column.
Turn ignition ON (Engine OFF).
Engine Check lamp turns on.
Any codes are indicated by a flashing lamp.
If Code is OK then Turn ignition OFF & Disconnect Connectors.
If there is a fault code check in the table below to see which sensor the code pertains to:
Reading the code: The long pulses (1.3 Seconds) indicate Tens and the short pulses (0.2 Seconds) indicate ones. Pulses are separated by Short Pauses (0.2 Seconds), multiple codes are separated by a Long Pause (1.8 Seconds). The codes are cycled.
11 Crankshaft position sensor
12 Starter switch
13 Camshaft position sensor
21 Engine coolant temperature sensor
22 Knock sensor
23 Mass air flow sensor
24 Idle air control solenoid
31 Throttle position sensor
32 Oxygen sensor
33 Vehicle speed sensor
35 Purge control solenoid valve
42 Idle switch
44 Wastegate control solenoid valve
45 Pressure sensor
51 Neutral position switch
Found this here. Frequently Asked Questions Hope it helps you out.
Cobb Accessport Stage 2.
JDM ej205 swap.
Home state: PA Crew
Chuck.
AllExtinct is offline
