BOV Install requires a tune? - Subaru WRX Forum
 20Likes
post #1 of 20 Old 10-11-2013, 12:33 PM Thread Starter
2010SubiWRX is an unknown
Hello there i'm new to the site just purchased my 2010 WRX sedan yesterday and i've been researching i want to do a BOV as my first mod (that i'll be making to the vehicle) i've read that installing a atmospheric BOV may require me to tune the vehicle afterwards? Just checking if i should be concerned about it or if it's BS
2010SubiWRX is offline
post #2 of 20 Old 10-11-2013, 12:36 PM
Awful 1st mod. Move along to the next item.
BLAZE2099 likes this.
post #3 of 20 Old 10-11-2013, 12:41 PM
Premium Member
the RIOT act's Avatar
BOV isn't an option even with a Protune man. Most people still have problems. Stick to a BPV if anything.
Sent from AutoGuide.com App
BLAZE2099 and arewmors like this.
Brandon - 13' SWP WRX Sedan
the RIOT act is offline
post #4 of 20 Old 10-11-2013, 02:46 PM
Don't you dare destroy that car with a BOV!!!!!
the RIOT act, Haw1es and arewmors like this.
post #5 of 20 Old 10-11-2013, 02:56 PM
Vendor
PROImportTuners's Avatar
PROImportTuners is more helpful than not
As most people mentioned already; a vent to air BOV isn't a very popular first mod since your car uses a MAF tune.
A "Vent to atmosphere BOV" causes the vehicle to run incorrectly since it allows air that has already been accounted for by the ECU to escape the intake system (Makes the car run poorly).
A better alternative would be recirculating the BOV if you choose to use one. Another alternative for your car is a more free flowing intake or a simple stage 1 reflash. Both of these options should provide better driveability than a vent to air BOV as a first mod.
If you need more info on and intake or flashtuner, just let me know and I'll be happy to help.
BLAZE2099 and 2010SubiWRX like this.
PRO Import Tuners
PROImportTuners is offline
post #6 of 20 Old 10-11-2013, 03:54 PM
06_hawk_eye's Avatar
06_hawk_eye is an unknown
It's been a long time since we have had this question on here as everyone has stated stay away from any bov. Even the hybrid ones can be a problem.. I switched from a turbo xs one and it was day and night when I switched back to the stock on. Huge difference. Cobb ap is a good first mod along with a downpipe. Straight to stage 2
06_hawk_eye is offline
post #7 of 20 Old 10-11-2013, 05:28 PM
You can't fix something that screws a closed loop boost system into a open loop system by tuning for it. The only good way to run a BOV is to get tuned for Speed Density(Read:you have no need for a speed density tune at this point). So, In short....don't touch a BOV and research the crap out of a recirculated BOV before you even begin to think that you need it and which one is better than a cheap part. It causes too many headaches if you don't go for quality over quantity with this decision.
post #8 of 20 Old 10-11-2013, 06:34 PM
Like a Cobb XLE 50/50
Or a GFB- go fast bits
post #9 of 20 Old 10-11-2013, 06:47 PM
boo-key's Avatar
Forge is another good one.
pzr2874, BLAZE2099 and arewmors like this.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #10 of 20 Old 10-13-2013, 01:13 AM Thread Starter
Alright Guys thank you appreciate it! already got a full exhaust from perrin up and down pipe and the dual catback. Any advice on what to do for the next modification?
post #11 of 20 Old 10-13-2013, 01:17 AM
Maybe a 3 port and a good protune from a reputable tuner and shop. And a Cobb access port idk if you have that yet or not man. Maybe a good set of tires and some suspension work.
2010SubiWRX likes this.
post #12 of 20 Old 10-13-2013, 02:27 AM Thread Starter
alright i def am thinking of the cobb v3 i believe it is but are there any tunes that are preset to run a bit better or am i on my own? and i was thinking about the cobb short ram intake any problem that could happen with that?
post #13 of 20 Old 10-13-2013, 04:00 AM
boo-key's Avatar
You need to tune for this!
psinuse likes this.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #14 of 20 Old 10-13-2013, 10:37 AM
Cobb makes a map for their intake too...
post #15 of 20 Old 10-13-2013, 01:17 PM Thread Starter
Thanks for the heads up on the tune issue i've felt it run funny seems to waste a lot of gas too could that be part of it? and what should i get to tune it is a Cobb V3 good?
Also about the Map sensor with the intake what's the difference between the cobb sensor and OEM?
Sorry guys for totally being a noob i'd like to do some more research on my own as well as to what are some good tips about the car what to do and not to do could anyone point me in the right direction?
