2002 wrx upgrade - Subaru WRX Forum
post #1 of 4 Old 02-23-2007, 06:18 PM Thread Starter
iceman4hm is an unknown
Exclamation 2002 wrx upgrade
Just got the IHI vf34, sti pink injectors, fuel pump, HKS downpipe and COBB access port V2.... Any info on tuning and setup to gain the best performance and HP...help setting boost level on turbo?? thanks
iceman4hm is offline
post #2 of 4 Old 02-26-2007, 12:55 PM
pearl_boxer's Avatar
pearl_boxer is more helpful than not
I believe the Cobb AP has the VF34 map, so just flash that in to your computer and see how she runs.
My advise is to get a protune with your setup. You cant adjust the boost with the AP unless you have the street tuner software. A protune will net you the best hp and torque gains.
Shaun
Protuned STI Limited #262
pearl_boxer is offline
post #3 of 4 Old 02-26-2007, 01:13 PM
Over all the Cobb OTS maps for turbo upgrades leaves alot to be desired, after you get everything loaded into the car go get a protune and you would be looking at alot more enjoyment than if you just load in the OTS map. 20-30whp gains can be had just from a good protune on the VF34 maps, from what I have seen.
post #4 of 4 Old 02-26-2007, 01:18 PM
wrxman420's Avatar
Flash in the vf34 ots map for now. Buy an intercooler (ssautochrome tmic) and then go get protuned. I would also suggest you look into a catback exhaust to go with your downpipe.
wrxman420 is offline
