-   New Member Intros (http://www.wrxtuners.com/forums/f120/)
-   -   2002 wrx= first car:) hood questions (http://www.wrxtuners.com/forums/f120/2002-wrx-first-car-hood-questions-33615/)
knobbywrx 02-19-2013 08:39 AM
hi guys,
i have a 2002 wrx that is my baby and is recently got backed into!Cry! looking into a carbon fiber hood and i wanted to know if anyone out there knows if you can put an OEM hood scoop on a carbon creations hood?
thanks
the RIOT act 02-19-2013 10:56 AM
1 Attachment(s)
Why not this?? Seibon OEM style
[ATTACH]6074[/ATTACH]
knobbywrx 02-19-2013 11:14 AM
ive looked into seibon hoods and truely i just cant afford them. i already have a 4 inch carbon scoop on the steel hood that i wanted to put on the new one
the RIOT act 02-19-2013 11:47 AM
Their's is $480 though right? With only $280 for a gap you'd prob spend that in fabrication, and also have a product that'll most likely have some type of ill effect from the fabrication ie: water damage, cracking in clear coat due to no support underneath for the scoop, or worst. Plus their hoods most certainly yellow out and will have clear coat problems like most off brands of Seibon. I'm totally for fabrication to set ourselves apart and never like to tell an OP what should and shouldn't be installed on THEIR car (cause I hate when people do it to me lol) but I'd just hold tight and go Seibon when you can save enough. I def wanna see some pics if you go your route though. Good luck OP
brfatal 02-19-2013 12:15 PM
Riot, Seibon is an off brand and their parts don't even come clear coated, you have to do that yourself. They will yellow just as all CF hoods will.
Careful OP. CF hoods are a lot of maintenance. They yellow and wear. And you're going to have to add the cost of clear coating to whatever you get (some come with it already done, but for the sake of upkeep you want it professionally redone before installation.
knobbywrx, the stock hood is aluminum, and actually slightly lighter than most of the faux carbon fiber hoods on the market.
the RIOT act 02-19-2013 12:49 PM
I've had 2 Seibon hoods and neither yellowed after 6+ years with both of them. No cracking, no air bubbles, no problems at all. Seibon hoods def come clearcoated too. Sure clear coating it professionally wouldn't hurt but it def doesn't need to be done right away that's for sure, or at all IMO. Not sure where you got your info but mine is first hand. Just curious...who's Seibon an off brand of?
the RIOT act 02-19-2013 12:52 PM
1 Attachment(s)
[ATTACH]6075[/ATTACH]
the RIOT act 02-19-2013 12:57 PM
If you're referring to VIS btw those things are JUNK lol! I bought and sold 2 of them before even installing for my RSX cause of air bubbles and cracking right out of the box. Again, just what I've had for experience first hand.
brfatal 02-19-2013 01:39 PM
[quote=the RIOT act;290934]I've had 2 Seibon hoods and neither yellowed after 6+ years with both of them. No cracking, no air bubbles, no problems at all. Seibon hoods def come clearcoated too. Sure clear coating it professionally wouldn't hurt but it def doesn't need to be done right away that's for sure, or at all IMO. Not sure where you got your info but mine is first hand. Just curious...who's Seibon an off brand of?
[color=gray]Sent from [url=http://www.autoguide.com/mobile]AutoGuide.com Free App[/url][/color][/quote]
They come gel coated, not clear coated. Surprisingly the general observation has been the opposite of your experiences. VIS seems to be decently longer lasting while Seibon is the quickest to degrade.
Seibon is an off-brand as none of their parts are original. They are copies of other brands products.
the RIOT act 02-19-2013 01:48 PM
I guess to each their own then. All I know is the VIS hoods I got had no exoskeleton like both my Seibon hoods and were littered with air bubbles and hairline cracks. And Seibon's website states it's clear coat as you can all see in my pic posted. I'm thinking someone should call a lawyer lol! Either way there's always supporters and protesters of every brand out there. All I can say is I boycot VIS lol! Good luck Though either way you go OP
brfatal 02-19-2013 04:24 PM
Either way, CF body parts should be painted anyways. :P
AllExtinct 02-19-2013 04:35 PM
If you get a CF hood then might as well spend the extra and get the scoop to match.
IMO.
mosc 02-19-2013 05:15 PM
Of course the unpainted CF hood is heavier than your stock hood. Painting it makes that problem worse. You are slowing your car down by spending money on added weight with no functional purpose. Put a vinyl wrap on it if you want some crazy look, they're light and cheap and can be taken off when you grow out of adolescence.
the RIOT act 02-19-2013 05:16 PM
[quote=brfatal;290943]Either way, CF body parts should be painted anyways. :P[/quote]
LOL...agreed...agreed! No more CF for me no matter what brand. Cause no matter what they'll all eventually cause headaches. Any headache costing $650+ is one I'd rather go without lol!
knobbywrx 02-21-2013 09:14 AM
so VIS hood are or are not junk? i only plan on running it in the summer months and the car gets washed/waxed weekly, will they last or should i just bite the bullet on the seibon one?
