-   Drag Strip Tech (http://www.wrxtuners.com/forums/f113/)
-   -   Wtf 14.7...... (http://www.wrxtuners.com/forums/f113/wtf-14-7-a-19924/)
bxwrx3 08-25-2007 06:24 PM
Wtf 14.7......
so i went to the track 2day and i got a 14.7. For a first timer is that ok??
R/t .315
60' 2.3
temp 95 degrees
baller_v24 08-25-2007 06:35 PM
yea that's not bad for a first timer, my first couple times i couldn't get lower than 15, some practice got me a 14.3 with exhaust. practice launching, ## 60ft could use some work. wait for a cold day too, should knock off and extra .1 or.2 if u go when it's cold.
mr04wrx 08-25-2007 08:41 PM
Better then me. I used a g-tech pro and I got a 15 flat, then again, my bud that weighs 260 was in the passenger seat.
Black Night 08-25-2007 11:00 PM
yeah as mentioned above, practice launching to bring down ## sixty foot times, 2.3 isnt the greatest, you should be at 2.0 or lower, you'll get it though....and yeah 95 degrees sucks for forced induction
bxwrx3 08-26-2007 09:35 AM
well im at stage 1 and a megan catback, so i was hoping to get better than like a 14.2, better than a stock WRX should do right?
baller_v24 08-26-2007 12:18 PM
should, with practice
Z/WRX 08-26-2007 06:18 PM
14's is average for a first timer but keep in mind that a stock 06-07 WRX will hit 13.8-13.7 with a really good driver. So with stage I and exhuast it should be a tick faster than that. With your stage I you should be aiming for high 13's.
JBWRX06 08-26-2007 06:40 PM
what should stage 2 hit?
VD5505 08-27-2007 12:11 AM
i have a stage 2 and i run a 8.40 in the 1/8 and a 1.71 60ft time so you should be around the same 60 ft times and you should be in the low low 13's
2006WRXTR 08-27-2007 09:16 AM
If it is relatively humid with 95 degree temperture, I doubt a stage two WRX will hit 13.6 or better.
Living in Texas, I had a 1.899 second 60' time; and a 14 second 1/4 mile. The STG2 STi's running that day were only getting 13.5's... primarily due to the outside temps and humidity. Ok... their 60' times were not the greatest either. :D
BOO$TIN$UBY 08-27-2007 03:27 PM
Yes, to combat heat... I used to bring two bags of liquor store ice with me in my cooler in the back seat :P I'd drive to the track, park on the grass, then put one bag on the intake manifold, and the other on top of the intercooler. I'd do this with the bag still unopened until the ice cooled everything down to ice cold, ha.... then I'd put the ice back in the cooler to prevent it from further melting. Anyways it made a HUGE difference in my 60ft times. Right out of the box I got a 14.99 at 89 mph with a 2.0 - 2.4 60ft time. After that consistent 15.5's and even a 16! Ewww for subies... After the new clutch, flywheel, exhaust (tbe and up-pipe), ic hoses, and the ice I was able to pull off a 14.18 @95 mph 1.9 60ft time, with a 14.3 at 93 right after that :) Now that my car is actually tuned (XPT STAGE II 93oct map, 16.3 psi mmmmmm) I can tell the car hauls faster. I haven't taken it to the track yet, but like the guys were saying before I should get a 13 something at least, especially if I pulled off the 14.18 without it. I guess I should bring more ice with me :beatentod Hopefully I get a 13.6 at 100mph or better with a 1.8 or 1.7 60 ft time!
reksio02 09-15-2007 07:08 AM
[QUOTE=Z/WRX;166969]14's is average for a first timer but keep in mind that [B][COLOR="Red"]a stock 06-07 WRX will hit 13.8-13.7[/COLOR][/B] with a really good driver. So with stage I and exhuast it should be a tick faster than that. With your stage I you should be aiming for high 13's.[/QUOTE]
No Comment!....!Thumbs Up
Black05WRX 09-16-2007 03:35 PM
With a Mile up I hit 14.3@89 mph on a stage1.....
Nuke209 09-30-2007 10:29 PM
it also depends on how the track was prepped too.
i would know...:mad:
shamrock 10-18-2007 10:22 AM
[QUOTE=bxwrx3;166934]well im at stage 1 and a megan catback, so i was hoping to get better than like a 14.2, better than a stock WRX should do right?[/QUOTE]
I would rather get a 14.2, than bust my transmission. These CARS are not meant to drag race. It may not happen now, but keep it up and someday you will start a post saying
"why do I hear grinding when I shift" or "why did my trans break". I am not trying to be a d!ck, but just letting you know what will happen, eventually
