-   Drag Strip Tech (http://www.wrxtuners.com/forums/f113/)
-   -   tire spin (http://www.wrxtuners.com/forums/f113/tire-spin-18196/)
provtec 05-10-2007 12:52 PM
tire spin
i have an 06 wrx with cobb down pipe, spt intake, cobb pulley, cat back ex. cobb acc. port stage 2. I can not get the car to get off line without tires breaking loose. i rev to about 4000 rps and slip the clutch out
mosc 05-10-2007 01:52 PM
what tires you running? Wheelspin with AWD at near-stock power levels on a good dry track should be impossible.
mxboy15u 05-10-2007 03:18 PM
I try to get my front tires to spin when I launch, it keeps my revs up and prevents bogging imo. Put some money in the bank for a new tranny if you keep launching like that though!
RJuni0rC83 05-11-2007 08:43 AM
... and how is it that you get just the front tires to spin ?
mxboy15u 05-11-2007 09:15 AM
I can usually spin them by clutch dropping between 4500 and 5000 rpm. This is on a PPG transmission and ACT 6 puck clutch, not recommended for those with stock components.
RJuni0rC83 05-11-2007 09:32 AM
lol yea that might help having those "extra parts" .. and for the rest of us who havent made it that far up the advancement list .. what do you recomend?
squidz 05-11-2007 10:31 AM
A little wheelspin is not a bad thing, it takes a bit of the stress off of the tranny and clutch. You want to learn how to modulate the clutch pedal to get the car to leave the line smoothly. When i launch my car (with stock gears) i usually launch it around 4500, and slip the clutch out slowly. I usually get a little wheelspin (mostly from the front tires), then the car hooks up, just be careful with the trottle till the car hooks, then roll into it. If you lay into it while the wheels are slipping a little, then you are coing to create more wheelspin, so just be patient, and practice finding that sweet spot where the wheelspin stops. It takes a lot of practice to be able to launch these cars properly. I can usually pull a 1.7-1.8 60 ft time with this method, and haven't hurt my tranny yet.
nagyhead 05-11-2007 11:17 AM
[QUOTE=squidz;152259]takes a lot of practice to be able to launch these cars properly. I can usually pull a 1.7-1.8 60 ft time with this method, and haven't hurt my tranny yet.[/QUOTE]
Yet being the key word
atxwrx 05-11-2007 12:27 PM
I have read a lot about modding your tranny on here. What is the most "cost effective" way if you don't have the $$ for PPGs? (How to get more bang for your buck) Before I upgrade my turbo, clutch or anything else. I want to redo my tranny. It's tempting to do all those other things first because you drop more for just the tranny than you can if you got the trubo, clutch, flywheel, exhaust, intercooler, protune, etc...,but I know that if you do that, you are asking for trouble.
atxwrx 05-11-2007 12:28 PM
Maybe I should have put this question in aother forum...
squidz 05-11-2007 12:30 PM
Honestly, the cheapest way to strengthen your transmission is to have your stock gears cryogenically treated. Other than a better gear ratio, that's the only difference between our gearsets and the RA gears.
You are in Austin, the cryogenics facility i work with is very close to you in Driftwood, TX. Check out this link:
[url]www.metalscience.com[/url]
Other than that, RA gears seem to be the most popular soloution, at about $1400-$1600 per set.
squidz 05-11-2007 12:31 PM
[QUOTE=nagyhead;152277]Yet being the key word[/QUOTE]
If it ain't broke...Don't fix it. If it is broke, it needed to be upgraded anyway. :rocks:
newtothegame 05-11-2007 04:54 PM
[QUOTE=atxwrx;152295]I have read a lot about modding your tranny on here. What is the most "cost effective" way if you don't have the $$ for PPGs? (How to get more bang for your buck) Before I upgrade my turbo, clutch or anything else. I want to redo my tranny. It's tempting to do all those other things first because you drop more for just the tranny than you can if you got the trubo, clutch, flywheel, exhaust, intercooler, protune, etc...,but I know that if you do that, you are asking for trouble.[/QUOTE]
Alot of people will tell you that the RAs are better, but most people and numbers say only about 10% stronger than stock. So honestly your best bet is to save and save some more until you can get the PPGs. I know how you feel though about wanting to mod away, but if you want the power and the ability to use it you got to attack and fix the weaker points first, like the tranny. I do know though, here in about 18months Im hoping the wife still says its ok to drop that money into my PPGs, then just waiting around some more until i can get the turbo and all.
