-   Drag Strip Tech (http://www.wrxtuners.com/forums/f113/)
-   -   Tips for a newbie ? (http://www.wrxtuners.com/forums/f113/tips-newbie-22625/)
BC_Girl 03-13-2008 12:08 PM
Tips for a newbie ?
Hello,
I'm new to this site and I own a 2004 Subaru Impreza WRX. I've had it for 7 months. Last summer, about 1 week after I purchased the car I took it to Knoll Gas Motor Sports park in Martin, MI to see if I had what it takes. My best time was 15.12 in the quarter mile, and my best reaction time was .520. Not to float my own boat, I had some good advice from a seasoned racer, but not too shabby for a first timmer right? Anyways, I was just wondering if anyone had any advice that may benifit me. I am still learning how to get a good start, an all wheel drive clutch is different than anything I have ever driven before, but I plan to go to an open test and tune on April 5th. I have a good feeling about it because I know my car better, but I don't want to damage my car while I'm just learning. Any tips would be appreciated.
Thanks,
Sara::D
Longshot 03-13-2008 12:29 PM
I posted this a bit ago....it's a really good how to that can get you off the line quicker with some practice. This technique fully utilizes the Subaru's AWD system as well as its turbo. It's post#3 in that thread.
[url]http://www.wrxtuners.com/forums/f113/1st-time-track-sucked-22409/#post187440[/url]
BC_Girl 03-13-2008 01:11 PM
Thanks for the advice, but I'm confused. "You can only build boost under no load conditions when the engine is accelerating at WOT" I'm a driver, my husband is my mechanic, but neither one of us is sure what "WOT" means, could you elaborate?
Longshot 03-13-2008 01:32 PM
WOT = Wide Open Throttle
BC_Girl 03-13-2008 01:50 PM
"I see" said the blind man. Thanks, I'll give it a shot, I think I need to find an empty parking lot and practice my take off.
Longshot 03-13-2008 02:21 PM
You're welcome and good luck. At the least if you can master this your 60ft times should come way down.
BC_Girl 03-16-2008 09:22 AM
Holy @#$%! What a difference. Had it out practicing my launch yesterday and I couldn't beleive how much power my car actually has now that I am learning how to drive it. I had to read that article a few times before I understood what I should do, but I reved it up to 3000rpm then right before I wanted to go I took it to 5000 and dropped the clutch. It launched like it had been kicked in the rear. Think I held the clutch a little too long though for fear of shock loading, because I could smell it burning. Can't do that again those things aren't cheap to replace. Anyways, thanks for the advice it really helped. Just have to get my %^&* foot off the clutch a little faster and I think maybe I should take it to 5500rpm to get a little more @#$% and get out of it.
nagyhead 03-16-2008 09:39 AM
be careful or you'll break a gear. I would never do a 5500 clutch dump.
loser05 03-16-2008 10:06 AM
i gots a question. it says rev up to 3k-3500 then at the lights go up to 5500 and release the clutch fast and smooth. ok so do u get the same response from ## car if u just rev to 5500 when u pull up.... i dont understand y u need to go to 3k 1st. can anyone explain.
MilesFox 03-16-2008 10:46 AM
does ## mean 'your' because no one can tell the difference between your and you're? just wondering, as i see it all over the place.
BC_Girl 03-16-2008 11:16 AM
From what I understand reving up to 3000-3500rpm gets the flywheel moving and gets u some boost ?! I think that's what I read.
OOPS: It stores torque and energy in the flywheel.
mr04wrx 03-16-2008 03:10 PM
just don't drop the clutch. That burning smell of the clutch is better then clunking in the transmission of a broken gear.
BC_Girl 03-16-2008 03:28 PM
There's really no happy medium then is there. I guess I gotta find the sweet spot in the clutch that doesn't buck me or burn it up. Where's the easy button when u need it? :)
mosc 03-16-2008 03:33 PM
the easy solution is an automatic. All serious drag cars are automatics
BC_Girl 03-16-2008 03:42 PM
Seriously???!!!! That's a joke right?! What's the fun in that?
