My dyno results - Subaru WRX Forum
post #1 of 10 Old 12-10-2007, 03:41 PM Thread Starter
wiked06rex is an unknown
My dyno results
This is with the stock TD-04 turbo.
I was only getting 17psi max, then tappering off to 12psi at redline.
Usually can get about 20-21 on the road.
Here are my mods:
3" TBE
"GT-Spec" EL Header
TGV Delete
"Unorthodox" UnderDrive Pulleys
Short Ram
"Perrin" Silicone Intake Tube"
Big TMIC
"TXS"MBC
"SMC" Alcohol Injection
"Enginuity" Custom Tune-By Me
Going to Import-Face Off this wekend shooting
for 12.60-12.70 @110 or so.
wiked06rex is offline
post #2 of 10 Old 12-10-2007, 04:14 PM
b7g
b7g's Avatar
b7g is an unknown
WOW!!!
I think you should be running more boost with Alchohol injection, but then again td04 is not very efficient at that level of boost (20-21 psi).
You are shooting a little high, but if you do get the numbers you're hoping, i'll say WOW again...
drive = freedom
b7g is offline
post #3 of 10 Old 12-10-2007, 04:23 PM
wrxman420's Avatar
Is that normal for your hp to start to fall off early like 5200+/- rpm? Nice numbers though.
wrxman420 is offline
post #4 of 10 Old 12-10-2007, 05:32 PM Thread Starter
I have gone 12.81 @ 106.1 before the Big TMIC,TGV Delete, and Meth injec.
I would think I could gain atleast 3mph, and 2 tenths, I also have gone much more agressive on my tune, scence the last time at the track.
post #5 of 10 Old 12-10-2007, 06:24 PM
b7g
b7g's Avatar
b7g is an unknown
Nice...
what was your 60 ft in the above run?
drive = freedom
b7g is offline
post #6 of 10 Old 12-10-2007, 08:25 PM Thread Starter
Originally Posted by b7g View Post
Nice...
1.71 60ft
8.05 @ 85.13 1/8 mile
post #7 of 10 Old 12-11-2007, 08:55 AM
Wow nice looking dyno. Cant wait to hear the times from the track after this. Good luck with it.
post #8 of 10 Old 12-11-2007, 10:00 AM
I was wondering the same thing
nagyhead is offline
post #9 of 10 Old 12-19-2007, 07:34 AM
96accord's Avatar
96accord is an unknown
Send a message via AIM to 96accord Send a message via Yahoo to 96accord
very nice numbers with the stock turbo on the '06!!
I have '07 WRX Stage 2 - no tune and I pushed 240whp.
96accord is offline
post #10 of 10 Old 12-19-2007, 08:53 AM
drs
drs is an unknown
your stage 2 with ap right so your tuned.
maybe his numbers drop so early cause of the mbc its set at one specific boost level not controlled by ecu.
drs is offline
