-   Drag Strip Tech (http://www.wrxtuners.com/forums/f113/)
-   -   My 2005 Sti Just Got Beat By A Evo Mr (http://www.wrxtuners.com/forums/f113/my-2005-sti-just-got-beat-evo-mr-23624/)
sean.rogers8 06-30-2008 12:48 AM
Well I have a 2005 STI with K+N short ram, COBB Access port, down pipe, Apexi cat back exhaust. what else do I need to beat this punk. Need some help got about 3000.00 need advise. Thanks
Sean
newtothegame 06-30-2008 01:29 AM
Either better driving would/could be a start, seeing as you didnt list his mods or power level. Or possibly a bigger turbo and supporting mods.
sean.rogers8 06-30-2008 09:46 AM
Evo Mr Mods That Beat My Sti
From what I could see he had a after market Front mount intercooler, N1 style exhaust, and a pretty decked out interior alot more thatn stock parts inside ie piller gauges. I completly destroyed him off the line by at least 2 car lengths it was the top end part that killed me, he ended up passing me at or around 100 mph a little before the 1/4 mark.
Sean
Longshot 06-30-2008 09:58 AM
If you were both at a stock turbo, the 16G has a bit more top end power than the vf-39. Since you got him by that much off the line I'd say it's more the cars than the drivers. You could pop a bigger turbo in there that will give you much more power. He could of also had a good protune that could've contributed to the higher top end.
sean.rogers8 06-30-2008 02:03 PM
Recommendations
So what is the turbo that I should look at to upgrade to and when I get this upgrade what am I needing to do.
Sean
Longshot 06-30-2008 02:35 PM
I'd say and 18 or 20G. You should run probably 650cc injectors in the 18G and 750cc in the 20G. For both you'll need a 250lph fuel pump, Walboro most likely. You also should look into a FMIC and of course a protune.
VD5505 06-30-2008 03:21 PM
+1 to the 20g turbo and 750cc injectors, your car would be a great running car with that setup make sure to get a protune as well like he said you can do all that stuff for under 3k as well
03 CrazyTaxi 06-30-2008 09:10 PM
+1 for the 20g. I'd suggest DW 880cc injectors with a Walbro 255 for that extra head room. Hallman Pro MBC, FMIC, protune *there won't be an OTC tune for all of this.
I'd also suggest a lightweight flywheel, lightweight crank pulley, upgraded clutch, GO CATLESS ALREADY!, oh and start saving for some gears possibly.
nagyhead 06-30-2008 11:49 PM
i though these types of threads were agaist the rules.
pzr2874 07-01-2008 06:59 AM
He was on the track Mike.... so he says :D
mosc 07-01-2008 08:20 AM
[QUOTE=nagyhead;199744]i though these types of threads were agaist the rules.[/QUOTE]
He's right. You need to at least post your times pls.
How's your clutch? Just wondering because if it's starting to go it can cost you a lot. The 6-speed can handle quite a bit so you could go with something grippier if your power levels are reasonable (stage 2 is quite reasonable). I run a "stage 2" clutch on my 6-speed.
zmanoside 07-01-2008 08:29 AM
he clearly states that he's racing the guy in the 1/4 mile, is there somewhere in the "rules" that states you MUST post times if talking about racing??? 20G all the way, with supporting mods and you would put a hurtin on him.
mosc 07-01-2008 08:31 AM
No, it's up to mod judgment if he's actually talking about a track or just adding "on a track" at the end of his street racing stories. Posting a slip though kind of makes the debate go away, no?
[color=red]Please PM me for further discussion on this issue. Discussing moderation on the forum is frowned upon.[/color]
WRXKidid775 07-01-2008 02:07 PM
There is a reason I bought an Evo instead of the STi. :) They make nasty power for cheap. Your extra half a liter will help you down low, but he can rev all the way up to 8500 rpms when you are shifting well before that. All evos have a FMIC, so unless you saw ARC or AMS or some other brand plastered on it they are kinda hard to tell if it is aftermarket or not.
I miss my evo.
03 CrazyTaxi 07-01-2008 05:36 PM
^^ That's why I bought the WRX instead of the STi. They shift sooner than I have to and they respond better to modifications IMHO.
