looking to hit 12's quarter mile - Page 2 - Subaru WRX Forum
post #16 of 37 Old 04-29-2008, 11:41 AM
VD5505's Avatar
doesnt aqumist have a fail safe that works with true boost like if it reads that the fluid is low or if the pump shuts off for some reason it will default to run on waste gate only, i thought i saw that somewhere
VD5505 is offline
post #17 of 37 Old 04-29-2008, 11:33 PM
Aquamist has a gangster failsafe. I would have no problems trusting it. The snow kits offer a failsafe that will revert you to wastegate boost only if it senses a problem but it isn't nearly as good as the Aquamist.
To compare it. Guys on evos usually run 22 ish psi on pump and between 26-28 on pump + meth with some timing as well.
you should be able to run mid to low 12s with that setup, a good 60 and a nice tune.
Robby
02 rex is gone.
I defected to an evo :)
Evo is gone :(
Now I got nothing.
WRXKidid775 is offline
post #18 of 37 Old 04-30-2008, 08:53 AM Thread Starter
boost_556's Avatar
appreciate all u guys response on this, will update u on my next run after i am finished with everything.
thanks again.
boost_556 is offline
post #19 of 37 Old 04-30-2008, 09:29 AM
BC_Girl's Avatar
Work on shifting faster also, that's one of my problems, I take to long to shift.
Boys will be boys, but girls will be fast !
BC_Girl is offline
post #20 of 37 Old 05-07-2008, 09:07 AM
You can throw all the mods in the world at a car and in the end it comes down to the driver.Doesn't matter what mods you have if you can't drive.Like VD5505,lots of guys run high 12's on a stock turbo set up.Plus your times will have lots of other factors:altitude,humidity,ambient temps,fuel........
dumdum is offline
post #21 of 37 Old 05-07-2008, 01:31 PM
VD5505's Avatar
i launch my car prob a little to hard i have always left the line at 7 grand but i just dont dump the clutch i wait for it to grab then i let off, i am keeping my fingers crossed still lol
VD5505 is offline
post #22 of 37 Old 05-07-2008, 05:03 PM
Not sure what EM you run but Opensource does have launch control now for 16bit ECU's
dumdum is offline
post #23 of 37 Old 05-07-2008, 05:40 PM
VD5505's Avatar
i run the cobb accessport, i wish i could have a launch control though.
VD5505 is offline
post #24 of 37 Old 05-08-2008, 03:06 AM
Cobb has launch control also. I know they have it for the AP 2, not sure if they have or you use the AP 1 though.
post #25 of 37 Old 05-08-2008, 08:48 AM
Only for the 32bit ECU's not the 16bit.That means It's only for the STi's and 2.5L wrx's (06+) and not for the 2.0L wrx's (02-05).
dumdum is offline
post #26 of 37 Old 05-08-2008, 05:27 PM
Oh sorry about that. Thanks for the correction Dumdum.
post #27 of 37 Old 05-13-2008, 08:47 AM Thread Starter
boost_556's Avatar
i argee with u 100% on the driver, i am still awaiting the tune and will be running race gas as well, those two runs i launched at abt 5800 rpm not dumping just feeding the clutch as others may say FEATHERING but will also work on making my shifts a little faster too oh and also those two test runs was on 20 psi will be pushing atleast 21 to 22 psi on my next runs.I know for sure the more u visit the track the more u get better its all abt practice too.
Also when i was there they had a subaru legacy with quite a few mods he was doing my times low 13's and after i found out wht rpm he launches i laugh 2000 rpm, told him to try 5500 did'nt listen quite well but launch @ 4500 and jump to 12.9 sec thank me later , so yeah alot has to do with the driver.
post #28 of 37 Old 05-13-2008, 09:32 AM
VD5505's Avatar
2 grand, lol my god thats like a really high idle, so what kind of times were you getting down to man??
VD5505 is offline
post #29 of 37 Old 05-15-2008, 11:30 AM Thread Starter
boost_556's Avatar
not quite sure wht u mean.
post #30 of 37 Old 05-15-2008, 11:55 AM
VD5505's Avatar
sorry i ment to ask what kind of times did you get your car to run??
VD5505 is offline
