-   Drag Strip Tech (http://www.wrxtuners.com/forums/f113/)
-   -   hit the drag strip yet another disappointment (http://www.wrxtuners.com/forums/f113/hit-drag-strip-yet-another-disappointment-27320/)
boost_556 10-10-2009 09:15 PM
Ok guys as usual i need some input on this.I went to englishtown this evening and only ran a 13.6 with a 1.8 60ft @101 MPH.MY problem is that my third gear which happens to be also my strongest and most important gear is locking up on me:(I know my car can run 12's but i am not able to do this since i have to slow down and fuss with my third which is being very reluctant to change under high rpm 6900.I am running a ACT 6 puck with rps pressure plate exedy flywheel.Is the mix and match causing this, or am i pushing a little more power than the stock tranny can handle or do my clutch just needs adjusting.
Oh also on this run i hesitated like about a second to get third since it was giving me a pretty hard time to change, which would have drop my time and increase my trap speed.
04paulieWRX 10-10-2009 09:50 PM
i shift my 04 wrx(2.0 liter) at 7500 rpm. shove it in third
02SportWagon 10-10-2009 10:58 PM
Ouch, synchros maybe? Just throwin that out there..
baller_v24 10-10-2009 11:58 PM
I cant believe you have an aftermarket clutch in that thing. You do realize that its best to stay with stock clutch with stock tranny? I really hope you dont have to go through yet another tranny. You could have a bad 3rd gear.
boost_556 10-11-2009 08:40 AM
but the thing is that i don't have any problems geting into third driving on the streets and shifts perfectly fine. should i put in a act street disc then?
Also would stock clutch be able to hold the power and torque?
boost_556 10-13-2009 04:31 PM
thanks guys for the input
