-   Drag Strip Tech (http://www.wrxtuners.com/forums/f113/)
-   -   1/4 track firebird raceway, 06 wrx w/ stage 2 (http://www.wrxtuners.com/forums/f113/1-4-track-firebird-raceway-06-wrx-w-stage-2-a-17386/)
atvrider450r 03-26-2007 06:33 PM
Ok, this was my best run of the day. My stage 2 kit includes APS Cold Air Intake, APS 3" Turbo Back Exhaust, APS Up-Pipe APS Top Mount Intercooler, and the Dyno-Comp ECU Re-Flash.. Best i could run was 14.03... I think its my launching, people have claim the stage 2 can hit low 13's but im not seeing it,
My times:
R/T : .231
60 : 1.962
330: 5.782
1/8: 8.956
MPH: 77.03
1000 : 11.719
1/4 : 14.037
MPH : 98.13
i_love_wrx03 03-26-2007 06:47 PM
How are you launching your REX?
atvrider450r 03-26-2007 06:50 PM
I usually launch at 4k which on my chart shows where i get maxium torque. Is it better to just drop the clutch, or gradually release it?
i_love_wrx03 03-26-2007 06:54 PM
Well I usually just drop it around 4k it seems to get me the best launch, if I let out slowly I seem to smoke my clutch.
atvrider450r 03-26-2007 06:57 PM
if tried both ways, i seem to bog if i just drop the clutch.. Just wondering if m times are ok or i need to work on my launching/ shifting
i_love_wrx03 03-26-2007 08:17 PM
The time your running are ok b, but from what you have on your REX I don't see why you should'nt see low 13 sec. Also when ever I launch my REX I try to feather the gas around 4k then RIGHT before you dump your clutch stomp your gas petal to the floor. If done correct you'll get an awsome launch!
atvrider450r 03-26-2007 09:49 PM
Awesome, thanks, ill give it a try
WRXKidid775 03-27-2007 03:12 AM
dropping your clutch from 4k isnt very nice to your tranny...start saving for a new one.
i feather the revs between 4-5k and then drop the clutch to wear it grabs and then slip it the rest of the way out. it sounds slow but if you do it right youl actually get better 60' times than just dumping your clutch and it wont burn your clutch either.
atvrider450r 03-27-2007 04:39 PM
I have launched it that way also, but I dunno doesn't seem like im doing it right. Latly i have been reving it between 3.5k -4k RPM and holding the clutch right before it actually moves the car (friction i guess its called) Then right as im about the go push the gas and let go of the clutch together.. It alittle jerk, but im gettin better and plan on trying that technique next time im at the track.. Any tips on shifting or when to shift?
WRXKidid775 03-27-2007 09:58 PM
i dunno since your redline is a little earlier than ours. i shift at 6.5k thats when the power starts to fall off.
run your car to redline and pay attention to when the power seems to fall off. thats where you should shift.
wagonracer 03-28-2007 01:09 AM
What's the altitude at Firebird ? That makes a big difference on your 1/8 and 1/4 mile time. If it's 5-6000 ft you shouldn't feel too bad. 60' needs work though !Thumbs Up
atvrider450r 03-28-2007 01:55 AM
umm in AZ pretty close to sea level.. ( cant use that excuse) !Notfunny!
well my dyno chart shows peak HP at 5500, while my redling is at 6500..
-kovy 03-28-2007 03:36 PM
I rev to 6k and drop fast then slow...shift at 6500 and I got 13.4 @ 99mph with intake and exhaust with no flash...you should get lower 13's....AWD is all about the launch...its your money maker...
dont be afraid to try different things...its the only way to know where you stand if you shift earlier or later or something...just dont be stupid about it...tranny and clutches usually arent the cheapest....
ohhNOwrx 03-28-2007 06:11 PM
Kovy Don't give him bad advice!! Do not drop your clutch at 6k, you will not be happy when your gears brake and you have to tow your car home.
atvrider450r 03-28-2007 09:02 PM
haha yeah dont want to hurt my pride and joy... ima try to refrain from dropping the clutch...ive been practiceing launching daily and getting better.. open track is this friday so ill post my new times and HOPEFULLY ill see some improvements
