-   -   WRX pistons change smog? (http://www.wrxtuners.com/forums/f103/wrx-pistons-change-smog-26222/)
BrokEnRex 05-16-2009 08:55 PM
Will changing pistons to aftermarket forged pistons , stock bore, and stock compression. will this change my outcome when i go to smog my car?
my engine failed over a year back, and im finally having the motor built, everything is pretty much ordered other then the pistons and crank and rod bearings.
I was lookin at the Wiseco 92mm pistons. Thanks
o yea, and after i pass smog, i am going to be putting a full turboback exhaust with a cobb ap ( i had this setup before and its plenty for what i am lookin for).
VD5505 05-17-2009 08:18 AM
No they wont in your case and since your staying with stock compression really. I would really go with CP forged pistons or JE. The thing about Wiseco you will have a little more piston slap with the engine is cold those pistons have always been like that but it is up to you man.
BrokEnRex 05-17-2009 12:11 PM
i want CP or JE but i cant find them with stock sizing and compression.
VD5505 05-17-2009 12:41 PM
[url=http://www.pandlmotorsports.com/]P&L Motorsports - Home[/url]
Give those guys a call, they are GREAT to deal with I have bought 2 STI shortblocks from them and they are super nice people. I also bought my CP pistons from them. So give them a call and they will hook you up man.
WRXKidid775 05-19-2009 02:42 AM
Even with the weiscos all you had to do is let the car warm up before you romp on it as with many aftermarket pistons but i do agree CP or JE would be a better option. Even if you change the compression it should not affect your smogablity as long as you have no codes in your ECU you should be set.
