WRX '02 Cylinder Heads cracked - any suggestions? - Subaru WRX Forum
post #1 of 10 Old 04-16-2009, 08:26 PM Thread Starter
I had my 2002 WRX (109,000 miles) in the shop to have a head gasket replacement and was told that there are cracks in both cylinder heads. There doesn't appear to be any coolant leaking at this point. The options I've been given:
1. Replaced both with Subaru heads ($1000 each plus labor).
2. Replace the entire engine.
3. Use the existing heads and pray.
I've done some research and have found places that will refurbish heads, but I haven't found any info about the reliability of the companies.
Any suggestions of other options or solid companies that reburbish head or provide new heads at a reasonable cost?
Any help would be greatly appreciated!
Thanks,
CompuPsych is offline
post #2 of 10 Old 04-16-2009, 09:28 PM
VD5505's Avatar
Where are the heads cracked at? The good thing about Alum heads are you can weld them. Ask to see where they are cracked at as well. Look around for some used head here is a website, give them a call and they might have some bare heads they can see ya.
P&L Motorsports - Home
VD5505 is offline
post #3 of 10 Old 04-16-2009, 09:32 PM
Depending on the internals, you can purchase blank heads for half that. I purchased two blanks for 800..
post #4 of 10 Old 04-17-2009, 01:02 PM
c2bcoolwrx's Avatar
Thanks,
WOW, $1000 each to fix :eek:! I think you need to find a new mechanic. I got a new EJ257 Short Block for $1850, back in August when my EJ205 got the knock (I told her to use protection, LOL). Now maybe a good time to consider a hybrid build.
c2bcoolwrx is offline
post #5 of 10 Old 04-17-2009, 01:40 PM
How big are the cracks? Mine had micro cracks that my machinist assured me wouldn't be a problem for a long time. I just used them. I'll get fresh heads on my next build, but they're fine for now.
post #6 of 10 Old 04-17-2009, 05:47 PM Thread Starter
cylinder heads cracked
The cracks run from the valves to the spark plugs. They are thin cracks (there isn't any wide gapping).
Thanks for the reference.
post #7 of 10 Old 04-17-2009, 07:44 PM
VD5505's Avatar
Well first off his heads are cracked any by doing a Hybrid he would have to use his EJ20 heads which are the prob right now so by him doing a Hybrid he would be in the same boat he is right now but just another $2,000 down for the EJ25 shortblock. I would take the heads to a machine shop and have them magnaflux both heads, you might be surprised what they say, they could just grind them down and call it good or do a little welding job on them. Try that and see what happens bro.
VD5505 is offline
post #8 of 10 Old 04-18-2009, 01:29 AM
My friend has the same thing. They put the motor back together and he has been running the car for a year with zero issues.
Kjott21 is offline
post #9 of 10 Old 04-18-2009, 05:10 AM
Cast aluminum can be welded much easier than cast iron.
dumdum is offline
post #10 of 10 Old 04-18-2009, 08:04 AM
VD5505's Avatar
+1 to that!!!
VD5505 is offline
