Who here has cams? - Page 2 - Subaru WRX Forum
post #16 of 25 Old 03-07-2007, 04:46 PM
PeteDucati is an unknown
My 4eat/20g/2.5litre with ported heads and Crower Stage II cams made ~30whp less than my tuner's STi with a Green and stock heads/cams. My car was tuned in 2nd without locking the converter, his was in the traditional 4th/5th gear.
The estimate of how much power the torque converter eats up varies between 20whp and 50whp.
PeteDucati is offline
post #17 of 25 Old 03-08-2007, 02:18 PM
Cams is one of the last thing most consider due to the money-power ratio.Definatly not one of the best bangs for the buck.I would probably want ported/polished heads and a valve job to get the most out of a cam swap.
dumdum is offline
post #18 of 25 Old 03-08-2007, 08:50 PM
But here is the thing.. The issue with Cams is the same that I've been saying over and over again.. IT's not about Peak numbers.. Cams along with P&P will definitly fatten up your power band which is MUCH better then peak numbers.. Coupled with a decent Turbo like a 20G will definitly make a difference...
post #19 of 25 Old 03-08-2007, 10:03 PM
nick4592's Avatar
Originally Posted by LiL Shoaf View Post
fatten up your power band which is MUCH better then peak numbers.....
Now if we can just convince more Shops/tuners of that
nick4592 is offline
post #20 of 25 Old 03-09-2007, 08:38 AM
I agree but equal length headers can produce the same results for MUCH less $$ and can easilly be a first mod that most people can install on their own where cams can't be justified untill alittle later down the road plus it's one of the more difficult installations.
dumdum is offline
post #21 of 25 Old 03-09-2007, 09:40 AM
True but most Subaru owners (like myself) don't like the sound of equal length headers. But with that aside I agree that headers are a good choice once you upgrade to a decent flowing turbo.. But imagine the gain with both.. LOL..
post #22 of 25 Old 09-04-2007, 08:40 PM
Circle_Nine is an unknown
Send a message via AIM to Circle_Nine
Originally Posted by 04caliwrx View Post
cams!!! THE PRICE OF CAMS is not that bad but the cost of install is close to $2000 that is just crazy, and for the power you gain about 20whp is not worth the cost at all, use the 3 grand and get a turbo and a new tmic and get up to 100whp depending the turbo and what the boost is set to!
...if you ever pay 2,000 for cam replacement you,
a.)should get slapped on the wrists
b.)need to learn a little bit about mechanics and swap them yourself
c.)atleast need to find a new technician
thats rediculous.
Circle_Nine is offline
post #23 of 25 Old 09-04-2007, 09:08 PM
JBWRX06's Avatar
JBWRX06 is an unknown
that post is about 6mths old there buddy, look at the dates of the last post
JBWRX06 is offline
post #24 of 25 Old 09-04-2007, 10:41 PM
Robby
02 rex is gone.
I defected to an evo :)
Evo is gone :(
Now I got nothing.
WRXKidid775 is offline
post #25 of 25 Old 10-08-2007, 12:00 AM
TwoCobras is an unknown
I'm using Cosworth cams. We tried to buy Crower, but the backlog was months. Until I get the trans built, I can't really say how well they work. For sure, we'll be well over 400/400 on a very conservative Mustang dyno. The trick, as you well know, is to figure out what you want out of an engine, and for what reasons, and then to put a package together that does exactly that. I really don't think it's necessary to P&P for most people. Simply deshroud the heads, make sure the valves fit properly. What a lot of people don't seem to realize is that whether or not you keep the stock cams, if you are going to try for big hp, then you better get new springs and retainers.
Hey, how do you like your ACT clutch? I put in a ClutchMaster 200, and it sucks big time. No way, no how can you avoid chatter in all gears, up and down both.
TwoCobras is offline
