What's the Difference in STi engines? - Subaru WRX Forum
post #1 of 11 Old 12-31-2007, 05:17 PM Thread Starter
Send a message via MSN to Jonpark
I'm trying to swap the engine w/ Sti engines.
I have 07 wrx but recently piston rings has been damaged now i need set of forged pistons or sti engine...
but i see that there are some different engines like... V5, V6, V7 sti engines
what's the difference and what are they?
291.11whp/321.13wtq 18psi
Jonpark is offline
post #2 of 11 Old 12-31-2007, 05:31 PM
IH8PVMNT's Avatar
how'd you manage to damage the piston rings ??
IH8PVMNT is offline
post #3 of 11 Old 12-31-2007, 07:11 PM
Jave's Avatar
might have been running rich like me and burned them up.
▼SbiΣ Mi▼
Jave is offline
post #4 of 11 Old 12-31-2007, 07:35 PM
IH8PVMNT's Avatar
would this be followed by a sudden lack of power..... i boost fine but car seems like it doesnt pull like it used to.... all i have is an spt intake
IH8PVMNT is offline
post #5 of 11 Old 01-01-2008, 07:37 AM
Turbos,ECU functions,intercoolers,cams,heads..... A Google search will bring up the technical specs.
dumdum is offline
post #6 of 11 Old 01-01-2008, 09:35 AM Thread Starter
this happened right after i got my car tuned with Enginuity.
local tuner did the tuning...
right after the tuning my car was smoking already...
and then couple of days later... boom!
The car was smoking so much i couldn't see what's coming behind me...
then the tuner said i need to replace the pistons because 07 models has problems
with piston rings and it just failed working now...
i was like what da heck....it was just working fine and right after the tuning...this happens...
but what can i say... how do i check if the piston rings damaged?
because i know my car was not running rich. previously Andy from verocious moto tuning did the tune and it was running perfect.
my car has VF39 with stock injectors..
Jonpark is offline
post #7 of 11 Old 01-01-2008, 09:51 AM
robert.lshoc's Avatar
put it back to stock and take it to subaru. If you put it all back the way it was they might not notice it was modded if they do at least you tried.
robert.lshoc is offline
post #8 of 11 Old 01-01-2008, 09:54 AM
Sounds like a bad turbo to me.
post #9 of 11 Old 01-01-2008, 10:23 AM
Jave's Avatar
nope rings. Lose of power and smoking very badly. I thought it was my turbo at first but pulled it and it was fine. Even sold it on Ebay.
▼SbiΣ Mi▼
Jave is offline
post #10 of 11 Old 01-01-2008, 10:38 PM Thread Starter
so what was it then?
was it the piston rings?
Jonpark is offline
post #11 of 11 Old 01-02-2008, 10:44 AM
Jave's Avatar
a compression test will tell you exactly what it is. mine was the rings cause I held compression during a wet test.
▼SbiΣ Mi▼
Jave is offline
