Well it finally happened - Subaru WRX Forum
post #1 of 77 Old 03-16-2006, 04:43 PM Thread Starter
nick4592's Avatar
I just found that my #3 cylinder is running low pressure (110) on my REX....which is causing some issues....so I think I am finally going to get the 2.5L bottom end and start making some real power....My only question is does anyone know where I can get a STI block for fairly cheap?
nick4592 is offline
post #2 of 77 Old 03-16-2006, 06:07 PM
WRXtreme's Avatar
NASIOC, I have seen them go for around $800, which if you ask me isn't bad at all.
WRXtreme is offline
post #3 of 77 Old 03-16-2006, 09:36 PM
imbeterthanu's Avatar
it might not even be your block, your head just might be warped.
▼SbiΣ Mi▼
mike
imbeterthanu is offline
post #4 of 77 Old 03-17-2006, 01:01 AM
9d2TSi's Avatar
I wouldn't think it would be his head, unless he overheated the car badly.
I'm thinking worn rings or maybe a headgasket.
9d2TSi is offline
post #5 of 77 Old 03-17-2006, 10:04 AM Thread Starter
nick4592's Avatar
I am sure that it is the rings...
nick4592 is offline
post #6 of 77 Old 03-18-2006, 03:03 PM Thread Starter
nick4592's Avatar
Looks like I am going to go with a STI closed block...should be able to push 25 psi easy with that....or do you all think I should go 2.3L stroker like a buddy of mine wants me to
nick4592 is offline
post #7 of 77 Old 03-18-2006, 07:20 PM
9d2TSi's Avatar
It's really a toss up there. I'd go with the STi block simply for the higher revving capabilities over the strokers. Do the STi block, head work, cams, and raise the rev limit. That would be sick.
Oh yeah, the 25 psi would be nice too.
9d2TSi is offline
post #8 of 77 Old 03-19-2006, 06:27 AM Thread Starter
nick4592's Avatar
EH....I dont think I am going to raise the rev limit til I get hardened internals...at the moment my No. 1 concern is gettin my Rex back on the road ....I just need to find out what will work best for me the 2.5L or a stroker....hell I even have some people telling me to just sleeve the EJ20 and fix the rings on the #3....so many choices so little money
nick4592 is offline
post #9 of 77 Old 03-19-2006, 01:48 PM
WRXtreme's Avatar
I personally would go with the 2.5L STi short block.
WRXtreme is offline
post #10 of 77 Old 03-21-2006, 05:26 PM
bigbadbuddha's Avatar
Images: 15
Definite +1 on the STI shortblock. Or the Cobb 2.2 stroker. Man it is sick....
Big Jae -
JDM version 7 bugeye
bigbadbuddha is offline
post #11 of 77 Old 03-21-2006, 06:04 PM
awd>fwd's Avatar
Sti block 100%!!
Brent
awd>fwd is offline
post #12 of 77 Old 03-21-2006, 06:09 PM
I just dropped in an STI block. I would say don't sleeve the 2.0 and attempt to keep it. As for the stroker they produce massive torque numbers but you can't rev them as fast, but I personally don't have any personal experience with them.. Here is what I know for sure.. Coupled with the GT35R turbo I noticed a Hugh increase in bottom end.. Even with my fuel map still getting the kinks worked out.. Definitely ditch the 2.0 for the stroker or the 2.5...
post #13 of 77 Old 03-21-2006, 06:14 PM Thread Starter
nick4592's Avatar
So you dont think fixing the problem and sleeving the EJ20 is worth it?......man I need to win the lotto
nick4592 is offline
post #14 of 77 Old 03-23-2006, 05:16 PM
Well you can sleeve it, but it costs what, 900 for Darton sleeves.. Plus you need rings and other assembly pieces, also you still have to disassemble to a short block anyway, I purchased my STI block from Kerven Subaru for 1,600.. An additional 500 gained me a nice bit of NOTICEABLE bottom end.. Just my suggestion.. But I can honestly say you will NOT regret going to the 2.5..
+1 for the Loto.
post #15 of 77 Old 03-23-2006, 07:50 PM
reefdiver550's Avatar
can you put in the sti block and still use the 40T turbo?
reefdiver550 is offline
