Upgrading Pistons but not rods? - Subaru WRX Forum
post #1 of 10 Old 08-31-2005, 04:19 AM Thread Starter
Krmnnghia is an unknown
The Car I am buying had toasted pistons but perfect Rods so the dealer I am buying it from had new JE pistons installed on the stock rods, Polished the crank and did some head work. Even though the Pistons are stronger am I to assume the internals are still basically stock strength due to having the stock rods. I am guessing this is the EJ20's weak point?
I know, I know...why in the hell wouldn't you replace the Rods too...Dealer didn't think about that I guess.
Thanks
Krmnnghia is offline
post #2 of 10 Old 09-01-2005, 06:50 PM Thread Starter
Anyone have any advice/info on this?
post #3 of 10 Old 09-01-2005, 10:42 PM
jwtarbaj's Avatar
Images: 11
jwtarbaj is more helpful than not
Yep the rods are still your weak point. They will need to be upgraded before you try and produce crazy power. IDK how much they are good for stock though.
jwtarbaj is offline
post #4 of 10 Old 09-02-2005, 12:17 PM
knot04 is an unknown
Send a message via AIM to knot04
tada stroker kit!!!!! $3180.
knot04 is offline
post #5 of 10 Old 09-05-2005, 05:19 PM
hondaeater is more helpful than not
IIRC the stock rods are good up to about 400WHP, pistons to about 300WHP.
hondaeater is offline
post #6 of 10 Old 11-20-2005, 11:46 PM
dunham is an unknown
they should have replaced rods while they were in there. Each rod wears differently where it connects to the crank and the wrist pin on the piston. New pistons with old rods (especially rods from blown pistons) will cause wear. Dont push your hp too high before checking on the condition of those rods. make sure your rods are still in manufacturers specs for oil clearance.
dunham is offline
post #7 of 10 Old 11-21-2005, 08:22 PM
stileguy's Avatar
stileguy is an unknown
450-500hp at the crank will be fine if you have a good tune without raising your rev limit. the stockers are quite strong, if you get detonation it may hammer the bigend to the point where it locks the rod onto the crank resulting a big mess, the main weak point is the big end fasteners, they fail when you raise the rev limit. if you keep the rev limit to the stock level and are sensible with the amount of timing advance you use then your motor will be fine with boost levels to 25psi. if they replaced big end bearings you will be fine. if the same bigends are in the engine as when the pistons let go then you may have problems.
why did it blow a piston? this is more important than the integrity of your engine, if the same engine management is being used you will blow another engine regardless of forged pistons.
stileguy is offline
post #8 of 10 Old 01-29-2006, 10:55 PM
04roadtuned is an unknown
ill tell you why the dealer didnt replace the rods
A: they were ok
and
B: stealerships are cheap and only spend what is necessary and nothing more. NOTHING MORE
04roadtuned is offline
post #9 of 10 Old 01-29-2006, 10:57 PM
does this mean you can change rods and pistons, and not have to resleeve the block to achieve lets say 450whp. and raise the rev limit with a little crank work and an upgraded valvetrain?
post #10 of 10 Old 01-29-2006, 11:12 PM
trek98xc's Avatar
trek98xc is an unknown
Send a message via AIM to trek98xc
if youre going in there you may as well do it all at one time. if you want to go all out get a stroker kit.
rob
▼SbiΣ Mi▼
trek98xc is offline
