Tgv Deletes - Page 3 - Subaru WRX Forum
post #31 of 36 Old 05-10-2006, 03:38 PM
I also ended up doing mine..
post #32 of 36 Old 05-10-2006, 04:11 PM
IppoJ is an unknown
Are they installed yet?
If so, what were your results?
IppoJ is offline
post #33 of 36 Old 05-10-2006, 05:21 PM
I honestly can't say as I did a TON of other mods all at the same time.. I can't narrow down one.. Sorry..
post #34 of 36 Old 01-22-2016, 03:33 PM
Swanman57 is an unknown
So am i reading this correctly? If I remove the butterfly valves but leave the bar in my ECU will not notice any difference?
Swanman57 is offline
post #35 of 36 Old 01-24-2016, 02:57 PM
boo-key's Avatar
Other than the increase of air coming into your engine no, your ecu will not notice a difference.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #36 of 36 Old 01-29-2016, 10:13 PM
dopey's Avatar
dopey is an unknown
You dont even need the full bar to trick the computer. I shortend mine so there was only a mm extruding into the runner. All u need is the gear installed witch you will notice will only rotate a certain amount each way(this is all the computer senses)
dopey is offline
