Stroker Kit - Subaru WRX Forum
post #1 of 6 Old 06-14-2003, 07:13 PM Thread Starter
WRX_STi is an unknown
Send a message via AIM to WRX_STi
Question Stroker Kit
What exactly is a stroker kit?
I was browsing vivid racing's page, and came across stroker kits.
Don't exactly know what it is, or what it does, but hopefully you guys do!
Thanks!
WRX_STi is offline
post #2 of 6 Old 06-14-2003, 09:56 PM
Cosmo's Avatar
Images: 15
Huh... huh... you said stroker....
Anyways, it takes a 2.0 liter motor and makes it either 2.2L or 2.5L, depending on the kit. It does this by increasing the amount that the piston travels via a new crankshaft and connecting rods, therefore increasing displacement.
Cosmo is offline
post #3 of 6 Old 06-14-2003, 10:29 PM
fc735's Avatar
no replacement for displacement, beavis! usually has a slightly larger piston, too. not too mention the LARGE amounts of machining and assembly time.....this is what you do AFTER you melt #3 piston cause you ran it too lean. hehehe....more powaaa! needed only in high HP applications, which means Koby will probly be doing it soon.....;-)
JOEY
fc735 is offline
post #4 of 6 Old 06-15-2003, 08:16 AM Thread Starter
Thanks! Thats kinda what I figured, but needed a better idea!
WRX_STi is offline
post #5 of 6 Old 06-16-2003, 10:59 PM
AC7880 is an unknown
stroke
As mentioned, the distance the pistons move increase via a different crank, and/or rods. You then also have to modify the cylinder head and/or gasket for the right "squish" (compression ratio) of the air/fuel mixture. Upside is inceased displacement and more torque.
Downside is cost, plus piston speed. You "might" have to limit engine RPM with a stroker if piston speed is "too fast" for reliability. Oil system and cooling system makes a difference.
As an example, Harley motorcyles can be pumped up via larger pistons, or increased stroke, or both. They are a good place to research the effects of larger displacement thru piston size or stroke effects, as they have been at it many years.
AC7880 is offline
post #6 of 6 Old 01-29-2006, 10:59 PM
04roadtuned is an unknown
define high HP applications please.
04roadtuned is offline
