So...I must admit my guilt - Page 8 - Subaru WRX Forum
post #106 of 174 Old 10-06-2011, 08:02 AM
Well you did get headwork... Good cams like Kelford/GSC beat the misconception that you give up low end to make more power up top. Chances are you're feeling the improvement in airflow from the pnp and cams.
post #107 of 174 Old 10-06-2011, 12:30 PM
Congrats on getting your car back! Now, don't forget that Fumoto oil drain valve
post #108 of 174 Old 10-06-2011, 10:01 PM Thread Starter
Yeah, I think the headwork with the headers are really making the most out of the crap boost for right now in the TQ department. I noticed how much just the headers made before, but with complementary headwork its even better. My profile needs updated now. I'll do it later when I have more free time on my hands.
I know the quick drain valve would eliminate any more mistakes on my end, but I'm still kind of on the fence about it. The failure rate or any mistakes are really low on the valve. But, idk...I still have to mill it around in my head.
post #109 of 174 Old 10-07-2011, 05:47 AM
The only failures on the valve are from ppl not installing it correctly.
You had no problem dumping 4-5K on the work you had done but "thinking" of buying $26 insurance. lol
Just get it
post #110 of 174 Old 10-07-2011, 07:00 AM
If you're worried about the little lever flipping open, you could always buy some type of clip or twist some wire tightly around it to keep it in place. Mine's still holding strong and completely leak-free after 28 oil changes.
post #111 of 174 Old 10-07-2011, 08:56 PM Thread Starter
Paul you forget labor charges and well...lets just say I wish it was only 4-5k to fix what one dumb oil drain plug ruined and then upgrade other things. I'm not getting the valve until my tuner is done changing its oil and has the protune on it.
post #112 of 174 Old 10-10-2011, 06:05 AM
I'd like to know what the $ came to.
Tried talking to the wife about doing a build and gave her the 4-5K MAX window.... She just lol'd and said, yeah sure... Let's get right on that. hhahaahaha
post #113 of 174 Old 10-10-2011, 07:19 AM
I'll just throw it out there, my motor was ~6000 in parts and machining alone plus labor
post #114 of 174 Old 10-10-2011, 10:45 AM
Then again, CP-e has crate motors for my car I was thinking about for WAY less than 6-7K
post #115 of 174 Old 10-10-2011, 02:55 PM
I'd hate to imagine how much I have in the motor in my car, but I used a lot of stock and used parts so the prices were a bit cheaper. If I had gotten "real cams", head work and had someone else build it, 10k would not have been out of the realm of possibilities...
I do miss the old days of high performance, but cheap 350 small blocks...
post #116 of 174 Old 10-10-2011, 03:09 PM
Ohh yeah, that number doesn't include the 207 block or any of the work I had done to it because I re-used it in my stroker build, with that and the parts I re-used. that was another $1000, I wasn't including the 207 heads either because I got them for free and just paid the machine work and the cams, and valvetrain is a wash with the parts from the other motor. I think if I totaled it up I'd be somewhere right around $11K-$12K (including value of the heads)
post #117 of 174 Old 10-10-2011, 03:53 PM
Hmmm I think I paid $300 for just a used bare block, didn't even have case bolts in it...
post #118 of 174 Old 10-10-2011, 08:25 PM Thread Starter
You guys are just going to town while I am in the big apple on vacation.
Well, lets just say this...
Short block, CP pistons side and top coated by swaintech, carrillo rods, the 09 short block came with a nitrided crank, ACL bearings, had to pay for the heads to be tanked and inspected, ported/reshaped the heads, valves with iconel exhaust valves from SuperTech, the builder charged extra to set the valve lash with the cams, GSC Stage 1 Cams, new buckets/shims (whatever my heads needed), valve seals, new timing belt with pulleys, new water pump, new oil pump, new oil assembly, new oil pan, 20 hours of labor for removal and installation of engine, inspection of the turbo by Blouch, half off on a new Dom 3 turbo because of salvageable parts, two oil changes, two oil filters, master gasket set, and a protune.
Does that sound like 5-6k? I don't have a exact amount on hand...but, do I need to say what the damage was? I'll just call it basically 13k. I'm also paying for someone else's experience and knowledge that has done this sort of thing more than a few times before. I don't have the time to piss around and try to get all of this stuff done myself. It took a long enough wait for it to be done by someone else. It'd take twice as long if I had to do it...the way my job is working me lately. Plus, the bearing shavings were in my oil which is why everything oil related was changed out.
post #119 of 174 Old 10-10-2011, 09:03 PM
Vacation, what the hell is that?...lol
Other than machining the block, cleaning the heads, new valve guides and crank balancing I did everything else myself, so I think that's where I saved a bunch. Again if I had to add up how much plus labor I'd be real scared to see that bill...
post #120 of 174 Old 10-10-2011, 09:39 PM Thread Starter
If all I wanted was the short block it would've been 4k probably. Again, I don't have the info in front of me.
