-   -   Piston question (http://www.wrxtuners.com/forums/f103/piston-question-13876/)
bigdirtysrt 08-03-2006 10:24 PM
Piston question
ok this is gunna sound really dumb but, hot do you put pistons into an EJ20 block WTF cause im lookin at pics and theres like, no right way to do it it looks like, or is it just me :confused: please lemme know
Ian 08-03-2006 10:41 PM
You would have to pull the motor out.
bigdirtysrt 08-03-2006 10:43 PM
no shit, but how do you install the pistons, like, the block is split in half with the crank sitting in the middle, now i can see compressing the pistons on one side and sliding them thru and bolting them to the crank, but when you slide the other half of the block on, how the #### do you get the pistons on the crank, or if you bolt them to the crank first, how do you compress the rings!? ahhhhhhhhhhhhhhhhhhhhhhhhhhhhh i dont get it
ScoobyWRX 08-03-2006 10:46 PM
What kind of pistons are you trying to install, OEM or forged aftermarket?
bigdirtysrt 08-03-2006 11:17 PM
ok im thinking about running forged internals but thast not what im getting at, it doesnt matter what kind of piston im talking about im talking about PISTONS in general, i understand you can drive 2 through 1 side of the block and bolt them up to the crank, but what about the other two? i cant come to see how the hell you put them in, do you bolt the rod to the crankshaft first, but then how do you install the wrist pin, or do you leave the piston on the rod and install it on before you slide the other half of the block on? but then how do you compress you rings to slide the piston in
WILL SOMEONE PLEASE GIVE ME A STEP BY STEP GUIDE ON HOW TO INSTALL PISTONS INTO THE BLOCK, FULLY! thanketh you
imbeterthanu 08-03-2006 11:29 PM
to install pistons. 1st u need a special piston tool. it looks kinda like a sleeve which, closes the rings. then u take a hammer and hit the piston with the ass end of the hammer. its easiest if u bolt it to the crank after their instaled.
any more questions just post.
ScoobyWRX 08-03-2006 11:30 PM
Get yourself a STi 2.5 shortblock, you don't have to worry about installing pistons and messing up clearances. You'll starting your car and f*ck up everything and have to do it all over again. BTW, do you know how to pull the motor, if not then you should be worrying about that before you ask how to install pistons.
bigdirtysrt 08-03-2006 11:33 PM
i know how to install pistons, just not in this damn motor, ok so lets say you use the RING COMPRESSOR, and compress them and slide them in how do you bolt the end caps on to the crank, theres no way to do it, even if you put the pistons all the way at BDC at each cylinder what do you do, bolt them to the crank and then hydraulically press the block together? WTF
imbeterthanu 08-03-2006 11:38 PM
your saying u cant get the rod over crank right? what about if u push the piston in half way. then guide it onto the crank?
bigdirtysrt 08-04-2006 12:00 AM
no thats not what im saying, ok here see if you can follow me, i have the engine disassembled, EVERYTHINGS APART, now, i installed the two pistons on one side on the crank, and then i bolted the motor back together and i want to install the pistons on the other side, but theres NO way for me to get to the end caps because THE MOTOR IS CLOSED, now what the #### do i have to do to get those pistons in
LiL Shoaf 08-04-2006 03:55 PM
On the side of the block there are hex plugs that you have to pull. I made my own slide tool to pull the wrist pin and it worked well. Let me see if I have any pictures..
Actually, I have my stock 2.0L block sitting on my floor, I will try to take some pictures and write up a how to latter this weekend.. Maybe Sunday...
Ian 08-04-2006 06:24 PM
Sorry your first post sounded confusing, like you didn't know what you were talking about, maybe I just mis read it. I'll admit my mistake, but theres no need to bash me cause of it.
bigdirtysrt 08-04-2006 07:40 PM
its cool but im not retarded, i was just asking for a friend, i dont even drive a wrx, and im sorry for bashing you
Vew 08-05-2006 12:01 AM
Haha, you both are funny. Now lets keep on topic, no excuses.
9d2TSi 08-05-2006 04:04 PM
Alright, both of you shut it. If you guys want to argue, do it off-line. You [B]will not[/B] do it in our tech forums, understood!!!
The [B]only[/B] reason this doesn't get deleted is because it's a very good question.
