oil leak - Subaru WRX Forum
post #1 of 3 Old 03-09-2015, 07:04 AM Thread Starter
oil leak
Ok so I bought a 2005 sti in august with a clean record on carfax. Come to find out after a week my car is leaking oil. I replaced the cylinder head and gasket and still leaks. Heavy smoke. My buddy helped me try to reboot a loose bolt but broke 3 of them in it at the very end. Any one have any idea what I can do to prevent this
mikesti05 is offline
post #2 of 3 Old 03-09-2015, 07:31 AM
GSMNZ's Avatar
Oil leaking from where? Is the smoke from your engine bay? left or right side? And what 3 bolts?
Need way more info. I mean you did the head gaskets yourself? Did you make sure to put the crankcase lines all back on?
GSMNZ is offline
post #3 of 3 Old 03-09-2015, 08:04 AM Thread Starter
I have a leak from my right head. White smoke coming from hood and out exhaust. Also leaks coolant. it was three bolts in same hole. . Bottom of cover next to the flash shield. Sorry I'm not to mechanically inclined. And no I went to pepboys"bad idea" to replace cover
