N/A ej25 swap to turbo EJ25 - Page 2 - Subaru WRX Forum
post #16 of 19 Old 12-04-2011, 02:12 PM
Well I build a 2.34L, I used almost entirely stock components, other than pistons and a few other little odds and ends it was stuff that most people don't want because they believe the stock parts are junk so I got it cheap. I would say that I still have well over $5000 in it and I build it myself, other than machine work on the block. I hand balanced everything and put the motor together. Brand new shortblock is $2000-2100. Put your heads and maybe a set of cams and you'd be still south of what I spend and it would handle a lot more than what you think. The basic idea is to spend money where it is needed and not on parts that you think you need because this guy or that guys did it or told you so...Trust me on this you can save yourself $1000s.
post #17 of 19 Old 12-04-2011, 03:11 PM
Justin, you got me there. Are the short blocks the same on the 02-05s? I was under the impression that the 2.5 Liter engines were different though. Which is what the OP is refering to.
The '02-'05 WRX blocks are all the same open deck blocks. The EJ255 and 257 are semi-closed, and you are right about the OP's EJ253 being open deck.
post #18 of 19 Old 12-04-2011, 03:47 PM Thread Starter
Chico89 is an unknown
sweet do you have like blue prints or something i could base an engine off of. since you have a built one?
Chico89 is offline
post #19 of 19 Old 12-04-2011, 09:11 PM
Good to know, thanks Justin. I know more about the EJ255/EJ257s.
